Введение
The front case of the Omaker M4 provides a protective layer for the speaker cone. Once the front case is removed, the speaker can be accessed.
Выберете то, что вам нужно
Flip the device over so the front of the device is facing upwards. Make sure to place the speaker on a flat surface
Use a T6 Torx Screwdriver to remove the four screws from the front of the device.
Carefully remove the front case by gently pulling it from the body of the device.
3 человек успешно провели ремонт по этому руководству.
