Введение
Removing the motherboard from the device is fairly simple. However, be careful not to remove the motherboard without removing the three screws and the wires from the speaker and microphone.
Выберете то, что вам нужно
Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
Remove the mic wire by carefully pulling the plug out of the socket.
Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
2 человек успешно провели ремонт по этому руководству.
