Введение
This guide will show you how to replace the front facing-camera assembly of the Onda V701. The front facing-camera is the only camera on the device and replacing it is a very easy process.
Выберете то, что вам нужно
Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
Remove the ribbon cables.
Gently pry the front-facing camera away from the back panel using a spudger.
Flip the gray locking tab of the ribbon connector up using a spudger.
Remove the ribbon cable from the connector.
