Выберете то, что вам нужно
Remove the SIM tray.
Using a plastic opening tool, carefully separate the back panel from the main body assembly of the phone. Be extra careful around the SIM slot or other weak areas.
You may encounter some resistance due to hidden locking clips around the inside edge of the phone. Not to worry; just move in one consistent direction around the phone as opposed to jumping from spot to spot!
Top to bottom, left to right, clockwise or counter clockwise, once we make it about half way around the device, the panel is easily removable by hand.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using a pair of tweezers, remove the plastic plugs.
Once the hidden screws are revealed, use a PH #00 screwdriver to remove the three 3.175mm screws.
Use the PH #00 screwdriver to remove the remaining six 3.175 screws.
Using a plastic opening tool, gently pry up the black plastic cover and remove it from the device.
After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
Once the battery has been freed, we use the ever handy black spudger to pry up and free the battery ribbon from its dock.
After the battery has been removed, use the spudger to disconnect the remaining ribbons.
Notice that there are two side ribbons, one on each side (volume up/down and power), and a top ribbon as well as those from the battery compartment.
After removal of the ribbons, there is one final screw. Once you have removed this, the motherboard easily pries out with spudger.
This is the only screw that differs in size. This screw is a philips 00, 3.00 mm. in length.
Инструмент, используемый на этом этапе:Tweezers$3.99
Once the motherboard has been removed simply pry off the rear facing camera with a spudger or angled tweezers.
5 человек успешно провели ремонт по этому руководству.
