Введение
Use this guide to replace the Color Wheel on the Optoma HD72. The Optoma HD72 uses a 6-segment color wheel that includes red, green, blue, yellow, cyan, and magenta. The wide color range provided by this color combination enables the projector to create a more lifelike and immersive visual experience.
The following symptoms may indicate a problem or need for replacement with the power supply.
- Distorted Color Reproduction
- Flickering Colors
- Reduced Brightness or contrast
- Unusual Color Tints: This could be seen as an unnatural overall color to the images or video.
A few warnings to consider when dissembling this device:
- Electrical Hazards: The Optoma HD72 contains high-voltage components, so be wary of electrical shock by ensuring the device has been turned off for at least 5-10 minutes.
- The color wheel is delicate and can be easily damaged if not handled with care.
Выберете то, что вам нужно
Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
Flip the device over and slightly lift the upper case, with care not to strain the two cables.
Disconnect the two cables that connect the top case to the motherboard.
Lift the upper case up and off.
Remove the four 2 mm Phillips screws that secure the motherboard.
Lift the motherboard up and out of the chassis.
Remove the three 2 mm Phillips screws that secure the black housing.
Lift the black housing off.
Remove the single 2 mm Phillips screw that secures the color wheel.
Lift the color wheel up and out of its housing.
Remove the single 2 mm Phillips screw that secures the circuit board to the side of the color wheel.
Use a sharp tool to cut the zip tie that secures the color wheel’s cables.
Remove the color wheel.
