Введение
Before you begin disassembly, be sure to have the necessary tools. You will need a Torx size T6 screwdriver, tweezers, and the device opening tool. You will remove the stylus and back plate in order to access the battery.
Выберете то, что вам нужно
Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
Carefully and forcefully pry the panels apart.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to unplug the battery cable from the motherboard socket.
Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
6 человек успешно провели ремонт по этому руководству.
