Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement
Выберете то, что вам нужно
    1. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 1: шаг 1, изображение 1 из 1
      • Remove the battery and memory card from the device.
      Спросите у FixBot
      Добавить комментарий
    2. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 2: шаг 2, изображение 1 из 1
      • Remove the single .5mm screw on the left side of the camera.
      Спросите у FixBot
    3. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 3: шаг 3, изображение 1 из 1
      • Remove 4 (0.5mm) screws from the right side of the camera.
      • There are two screws at the top.
      • There are two screws at the bottom.
      Спросите у FixBot
    4. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 4: шаг 4, изображение 1 из 1
      • Remove 5 screws from the base of the camera.
      • There are two (0.2mm) screws next to the battery compartment.
      • There are three (0.5mm) screws around the tripod base mount.
      Спросите у FixBot
    5. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: шаг 5, изображение 1 из 1
      • Slowly open the back cover away from the device
      • The wrist strap bar can easily be lost so now is a good time to remove it.
      • Use caution. The rear cover is attached to the Main PCB via cables. You will need to release these cables before removing the rear cover.
      Спросите у FixBot
    6. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: шаг 6, изображение 1 из 2 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: шаг 6, изображение 2 из 2
      • Detach both ribbon cables using a spudger or other method.
      • Lift the black clip upward, unlocking the ribbon cable
      • Once the clip is in the up position you can slide the cable out. Release cable by pulling the cable out.
      • DO NOT pull on the Back case to release the cable.
      Спросите у FixBot
    7. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: шаг 7, изображение 1 из 1
      • Screw Arrangements
      • Make sure you organize your screws to make re-assembly easier.
      Спросите у FixBot
    8. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 8: шаг 8, изображение 1 из 1
      • Remove the back casing from the camera.
      Спросите у FixBot
    9. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: шаг 9, изображение 1 из 3 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: шаг 9, изображение 2 из 3 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: шаг 9, изображение 3 из 3
      • Use a spudger or other tool to release the 3 clips between the LCD case and housing.
      • Note: when re-assembly all 3 clips need to be seated in the grooves as shown in the 2nd picture.
      • Lift LCD out as shown in 3rd picture
      Спросите у FixBot
    10. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: шаг 10, изображение 1 из 1
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Sales Cameraparts4you
Участник с: 07/01/16
3 468 Репутация
Автор 22 руководств
3 Комментарии к руководству
Very well presented and helpful - thank you.
It sems important to use the correct screwdriver and my impression is that the screws are JIS rather than Philips.
So far I have been unable to locate a replacement screen with back light (I assume the back light is connected by the narrower ribbon cable).
George Winspur - Ответить Поделиться
I  Like my Panasonic  DMC-TZ3  , paid 300 way back in 2007  and has flawlessly  perfect, till I Dropped it in the case  …
IT still take pictures,  store on Memory, etc  all functions work , and can down load to computer ..
BUT the Back LCD  I can barely see unless I put a LIGHT to it ….
SO I assume I screwed the Back Light,  … can anybody help ?
Gary Trembley - Ответить Поделиться
Hi…. the backlite cable might have come loose or damaged. I would disassembly the unit and re-insert the backlite cable to see if that does the trick.. Otherwise you would have to invest in a new Display ASSY or backlite. A used backlite or Display assy is not that expensive and easy to replace..
Sales Cameraparts4you - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 16
За последние 30 дней: 55
За всё время: 4,830
