Выберете то, что вам нужно
While holding the switch away from the battery, push the battery out of the slot.
Remove 5 screws from the side panel body of the camcorder.
Use the spudger to remove the top of the camcorder.
Remove the side panel of the camcorder.
Remove the top panel of the camcorder.
For help with this step see prerequisite guide: Lens Clean.
Peel back the black tape holding the wire strip to the camcorder screen.
Unclip the small latch from the wire strip.
1 Комментарий к руководству
Steps 1-4 are good pre-reqs.
Are all of steps 5-8 absolutely necessary for LCD screen replacement?
Step 9-bullet 3: Change to 'note' rather than bullet point and put it first.
Step 11-bullet 2: List the # of screws to be removed and with what screwdriver. Show 2nd picture of screws to remove on actual LCD door.
Step 11-bullet 3: Change to a "caution" rather than just a bullet. Also we had a spring fall out at this step with no idea where it came from. Perhaps you could address this.
Step 12- We actually had to use a 2nd spudger to pry it apart. One as a wedge and one as a lever to separate.
Step 14-bullet 2: change to a "Warning" symbol.
Seems to be an incomplete guide, as the LCD screen is still affixed to the device.
