Введение
Use this guide to replace the camera lens of your Panasonic Lumix DMC-ZS25. It will describe the procedure to disassemble your camera in order to replace the lens.
Выберете то, что вам нужно
Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
Remove the two 2.60 mm screws located next to the battery.
Use the iFixit opening tool to open the outer cover of your device.
The easiest place to open your device is from the HDMI port.
Use a spudger to detach the ribbon cable.
After releasing the screen cable, use the iFixit opening tool to lift the button board.
Once you hear a "click" sound, you have successfully opened the buttons board.
Open the two 4.20 mm screws to remove the inner cover located beneath the screen.
Use the spudger to unlock the screen cables from the circuit bored. Carefully, lift up the black clip up to release the cables.
Use your hands to remove the lens.
2 человек успешно провели ремонт по этому руководству.
