Введение
This guide provides detailed instructions on how to remove and replace the battery from your Philips TAS7505 Speaker. It is vital to understand that this procedure requires you to detach the outside shell of the speaker, which may not reattach well. Proceed with caution.
Replacing worn-out batteries is crucial to maintaining the longevity of your speaker. By replacing the battery, you can ensure that the speaker continues to function optimally and extends its lifespan. If you do not mind minor cosmetic changes to your speaker, this procedure should not cause any issues.
Выберете то, что вам нужно
Remove the rubber dampener from the bottom of the speaker using your opening tool.
Remove the four Phillips #0 screws attached to the cover and remove with the opening tool.
Еще один человек закончил это руководство.
