Введение
The spring is located within a slender metal mount that is screwed into the front underside of the Polaroid. It is below the camera lens and can be seen through the mount it is within.
Выберете то, что вам нужно
Fully extend the bellows to prevent collapse using the #1 tab.
Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
2 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Thank you so very much!!!
You saved my camera and my sanity!!!!
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
