Введение
The spread roll spring is a vital part of the polaroid that ensures that your developing photo will exit the camera once your photo is taken.
Выберете то, что вам нужно
Push the lever on the bottom of the camera towards the left.
Open the rear door of the camera.
Unlatch the red clip on the side.
Lift the rollers up.
Position the camera with the back cover closest to you.
Remove the rear roll by using the plastic opening tool to take it off the metal frame.
Then remove the front roll by pushing away from you with the plastic opening tool.
Инструмент, используемый на этом этапе:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Unscrew the three 2.5 mm screws (attached to the metal plate) with a 3.0 flathead screwdriver. Then take off the metal plate.
