Введение
This guide will show you the steps to replace the base panel on the Porter Cable 690LR Router. It's quite difficult to mess this one up. Just make sure when you replace the base panel you screw it back in right side up.
Выберете то, что вам нужно
Undo the black latch located on the base of the router by pulling upwards from underneath it.
Orient the base so the black circular plate is facing you. Locate the three silver screw heads.
Use a flathead screwdriver to take off the three 10 mm screws.
Еще один человек закончил это руководство.
1 Комментарий к руководству
Aynı ürünü kullanıyorum..! Son birkaç yıldır Porter Cable ürünlerini kullanıyorum
Ancak bunu bu siteden satın aldım - https://www.raptorsupplies.com/b/porter-...
