Porter Cable 690LR Power Cord Replacement
Выберете то, что вам нужно
    1. Porter Cable 690LR Power Cord Replacement, Power Switch: шаг 1, изображение 1 из 2 Porter Cable 690LR Power Cord Replacement, Power Switch: шаг 1, изображение 2 из 2
      • Use a Torx screwdriver to unscrew the 25.4 mm screws found at the top of the model.
      Спросите у FixBot
      Добавить комментарий
    2. Porter Cable 690LR Power Cord Replacement: шаг 2, изображение 1 из 2 Porter Cable 690LR Power Cord Replacement: шаг 2, изображение 2 из 2
      • Remove the top by gently lifting the cover from router body.
      • Be careful when pulling the top from its place; wires connect the switch to the electrical cord and could be pulled loose or damaged.
      Спросите у FixBot
    3. Porter Cable 690LR Power Cord Replacement: шаг 3, изображение 1 из 1
      • Use a spudger to pull off the plastic covering of the power switch.
      • Don’t be afraid to really pry underneath the plastic (no components of the router will be damaged if you do so).
      Спросите у FixBot
    4. Porter Cable 690LR Power Cord Replacement: шаг 4, изображение 1 из 1
      • Push the power switch through the top of the router. The power switch should now be completely detached from the router (besides the wire connections).
      Спросите у FixBot
    5. Porter Cable 690LR Power Cord Replacement: шаг 5, изображение 1 из 2 Porter Cable 690LR Power Cord Replacement: шаг 5, изображение 2 из 2
      • Find the wire plugs which are attached to the power switch. These connections are located at the back of the plastic box that houses the switch.
      • Use the spudger to carefully loosen the metal and rubber coverings, and detach the connections from the switch.
      • While some force is needed in order to successfully pull the connections free, have care in making sure that you don’t damage any of the metal components. If needed you may carefully use a metal spudger instead of a plastic opening tool.
      Спросите у FixBot
    1. Porter Cable 690LR Power Cord Replacement, Power Cord: шаг 6, изображение 1 из 1
      • Use a pentalobe screwdriver to unscrew the 11 mm screw.
      Спросите у FixBot
    2. Porter Cable 690LR Power Cord Replacement: шаг 7, изображение 1 из 3 Porter Cable 690LR Power Cord Replacement: шаг 7, изображение 2 из 3 Porter Cable 690LR Power Cord Replacement: шаг 7, изображение 3 из 3
      • Use a pair of pliers to cut the white and red wires where they are crimped and the white wire connector.
      • Reminder: When following the guide in reverse order, you will need to remove a small section of the rubber insulation to reveal the wire. The wires will then have to be twisted together and covered with a new plastic housing. This process will shorten the wires every time the power cord is replaced.
      Спросите у FixBot
    3. Porter Cable 690LR Power Cord Replacement: шаг 8, изображение 1 из 3 Porter Cable 690LR Power Cord Replacement: шаг 8, изображение 2 из 3 Porter Cable 690LR Power Cord Replacement: шаг 8, изображение 3 из 3
      • Locate the two 20 mm screws on the base of the power cord.
      • Use a pentalobe screwdriver to unscrew the screws.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Jaymes Ullrich
Участник с: 10/05/16
343 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 20-7, Livingston Fall 2016 Участник Cal Poly, Team 20-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G7
4 членов
Автор 6 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 24
За всё время: 1,387
