Введение
These steps will show you how to install the top left cooling fan unit.
Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
20 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
