PowerBook G3 Wallstreet Power Card Replacement
Выберете то, что вам нужно
  1. PowerBook G3 Wallstreet Power Card Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
    Спросите у FixBot
    Добавить комментарий
  2. PowerBook G3 Wallstreet Power Card Replacement: шаг 2, изображение 1 из 1
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    Спросите у FixBot
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    Спросите у FixBot
  3. PowerBook G3 Wallstreet Power Card Replacement: шаг 4, изображение 1 из 1
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
    Спросите у FixBot
  4. PowerBook G3 Wallstreet Power Card Replacement: шаг 5, изображение 1 из 1
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
    Спросите у FixBot
  5. PowerBook G3 Wallstreet Power Card Replacement: шаг 6, изображение 1 из 1
    • Your laptop should look approximately like this.
    Спросите у FixBot
  6. PowerBook G3 Wallstreet Power Card Replacement, Heat Shield: шаг 7, изображение 1 из 1
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
    Спросите у FixBot
  7. PowerBook G3 Wallstreet Power Card Replacement: шаг 8, изображение 1 из 1
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
    Спросите у FixBot
  8. PowerBook G3 Wallstreet Power Card Replacement, Hard Drive: шаг 9, изображение 1 из 1
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
    Спросите у FixBot
  9. PowerBook G3 Wallstreet Power Card Replacement: шаг 10, изображение 1 из 1
    • Grasp the hard drive bracket on the left side and pull up and to the left.
    Спросите у FixBot
  10. PowerBook G3 Wallstreet Power Card Replacement: шаг 11, изображение 1 из 1
    Спросите у FixBot
  11. PowerBook G3 Wallstreet Power Card Replacement, Processor: шаг 12, изображение 1 из 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Remove the processor by sliding it up and to the right.
    • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
    • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
    Спросите у FixBot
  12. PowerBook G3 Wallstreet Power Card Replacement, Modem: шаг 13, изображение 1 из 1
    • Remove the single Phillips screw from the modem.
    • Disconnect the orange PMU cable by pulling it directly up.
    Спросите у FixBot
  13. PowerBook G3 Wallstreet Power Card Replacement: шаг 14, изображение 1 из 1
    • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
    • Remove the modem by sliding it up and to the right.
    Спросите у FixBot
  14. PowerBook G3 Wallstreet Power Card Replacement: шаг 15, изображение 1 из 1
    Спросите у FixBot
  15. PowerBook G3 Wallstreet Power Card Replacement, Clutch Cover: шаг 16, изображение 1 из 1
    • Push the display back so that it lies flat.
    • Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
    • Repeat the previous step on the left side.
    Спросите у FixBot
  16. PowerBook G3 Wallstreet Power Card Replacement: шаг 17, изображение 1 из 1
    • Lift the clutch cover off by rotating it up and then toward you.
    Спросите у FixBot
  17. PowerBook G3 Wallstreet Power Card Replacement, Display: шаг 18, изображение 1 из 1
    • Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
    Спросите у FixBot
  18. PowerBook G3 Wallstreet Power Card Replacement: шаг 19, изображение 1 из 1
    • Disconnect the orange display inverter cable on the right side of the computer. Grasp the cable near the connector and pull directly up.
    • Make sure that both cables are free from the plastic casing before proceeding to the next step.
    Спросите у FixBot
  19. PowerBook G3 Wallstreet Power Card Replacement: шаг 20, изображение 1 из 1
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black T8 Torx screws.
    Спросите у FixBot
  20. PowerBook G3 Wallstreet Power Card Replacement: шаг 21, изображение 1 из 1
    • Turn the laptop back around so that the screen faces you.
    • Adjust the display so that it is in a vertical position.
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts
    Спросите у FixBot
  21. PowerBook G3 Wallstreet Power Card Replacement: шаг 22, изображение 1 из 1
    • Your laptop should look like this.
    Спросите у FixBot
  22. PowerBook G3 Wallstreet Power Card Replacement, Upper Case: шаг 23, изображение 1 из 1
    • Remove the four T8 Torx screws from the upper case.
    Спросите у FixBot
  23. PowerBook G3 Wallstreet Power Card Replacement: шаг 24, изображение 1 из 1
    • Turn the laptop over.
    • Remove the eight T8 Torx screws from the bottom casing.
    • There are two longer screws in the front left and front right corners; make sure to put them back in the proper place when reassembling.
    Спросите у FixBot
  24. PowerBook G3 Wallstreet Power Card Replacement: шаг 25, изображение 1 из 1
    • Disengage the small locking tab by pressing in on the upper case to the right of the PMU connector.
    • Lift the upper case up just enough so that the tab rests on its metal bracket.
    Спросите у FixBot
  25. PowerBook G3 Wallstreet Power Card Replacement: шаг 26, изображение 1 из 1
    • Grasp the upper case near the back left corner and lift up partly so that you can access and disconnect the audio in/out cable from the sound card in the upper right corner of the case.
    • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cable.
    • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
    Спросите у FixBot
  26. PowerBook G3 Wallstreet Power Card Replacement: шаг 27, изображение 1 из 1
    Спросите у FixBot
  27. PowerBook G3 Wallstreet Power Card Replacement, Power Card: шаг 28, изображение 1 из 1
    • Remove the single black T8 Torx screw from the power card.
    • Grasp the power card near the black plastic shield toward the center of the case and lift up.
    • Occasionally, a post connecting the power card to the logic board will come out with the power card.
    Спросите у FixBot
Заключение
6 человек успешно провели ремонт по этому руководству.
Прикрепленные документы
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
1 Комментарий к руководству
I’ve determined that my Voltage Regulator PMU Charge Charger Card, 820-0917-A on the M4753 Powerbook G3 Wallstreet is burned out. I want to replace the burned out parts on the board. Is there a circuit board diagram somewhere on the internet? If so, please let me know for this. Thanks
SyFyGy 1 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 13
За последние 30 дней: 55
За всё время: 7,022
