PowerBook G4 Titanium Onyx Upper Case Replacement
Выберете то, что вам нужно
  1. PowerBook G4 Titanium Onyx Upper Case Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    Спросите у FixBot
    Добавить комментарий
  2. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 2, изображение 1 из 1
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
    Спросите у FixBot
  3. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 3, изображение 1 из 1
    • Your laptop should look approximately like this.
    Спросите у FixBot
  4. PowerBook G4 Titanium Onyx Upper Case Replacement, RAM: шаг 4, изображение 1 из 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to ÒpopÓ up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
    Спросите у FixBot
    • Turn the G4 over.
    • Remove the eight T8 Torx screws from the lower case.
    Спросите у FixBot
  5. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 6, изображение 1 из 1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    Спросите у FixBot
  6. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 7, изображение 1 из 1
    Спросите у FixBot
  7. PowerBook G4 Titanium Onyx Upper Case Replacement, Airport Card: шаг 8, изображение 1 из 1
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
    Спросите у FixBot
  8. PowerBook G4 Titanium Onyx Upper Case Replacement, Hard Drive: шаг 9, изображение 1 из 1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
    Спросите у FixBot
  9. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 10, изображение 1 из 1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    Спросите у FixBot
  10. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 11, изображение 1 из 1
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    Спросите у FixBot
  11. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 12, изображение 1 из 1
    Спросите у FixBot
  12. PowerBook G4 Titanium Onyx Upper Case Replacement, DVD Drive: шаг 13, изображение 1 из 1
    • If your G4 has a CD-RW or Combo drive, the pictures in the following steps will not exactly match your computer.
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
    Спросите у FixBot
  13. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 14, изображение 1 из 1
    • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
    • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
    Спросите у FixBot
  14. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 15, изображение 1 из 1
    • Turn the G4 over.
    • Disconnect the orange DVD ribbon cable from the logic board using a spudger or the tip of your finger
    Спросите у FixBot
  15. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 16, изображение 1 из 1
    • Remove the DVD drive by lifting the right edge up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    Спросите у FixBot
  16. PowerBook G4 Titanium Onyx Upper Case Replacement, Modem: шаг 17, изображение 1 из 1
    • Turn the G4 over.
    • Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
    Спросите у FixBot
  17. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 18, изображение 1 из 1
    • Lift the modem out by pulling up and to the right.
    • The plastic shielding on the modem may catch on the computer's case. Rocking the modem from side to side will help free the modem.
    Спросите у FixBot
  18. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 19, изображение 1 из 1
    • Disconnect the connector cable from the modem.
    Спросите у FixBot
  19. PowerBook G4 Titanium Onyx Upper Case Replacement, Logic Board: шаг 20, изображение 1 из 1
    • Remove the single T8 Torx screw located near the silver heat pipe.
    Спросите у FixBot
  20. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 21, изображение 1 из 1
    • Disconnect the three indicated connectors from the logic board.
    • Disconnect the orange PC card cage connector from the logic board.
    • The large multicolor cable may be difficult to free.
    Спросите у FixBot
  21. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 22, изображение 1 из 1
    • Turn the G4 over.
    • Remove the three T8 Torx screws from the logic board.
    • Be sure not to lose the rubber washers protecting the logic board from the lower two screws.
    Спросите у FixBot
  22. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 23, изображение 1 из 1
    • Disconnect the indicated connectors from the logic board, removing tape as necessary.
    Спросите у FixBot
  23. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 24, изображение 1 из 1
    • Carefully lift the logic board up and pull it away from you.
    • This step requires some force, but if the logic board will not come up, make sure you have removed all screws and connectors necessary.
    • Remove the logic board from the computer.
    Спросите у FixBot
  24. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 25, изображение 1 из 1
    Спросите у FixBot
  25. PowerBook G4 Titanium Onyx Upper Case Replacement, PC Card Cage: шаг 26, изображение 1 из 1
    • Remove the two T8 Torx screws that secure the PC Card cage.
    Спросите у FixBot
  26. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 27, изображение 1 из 1
    • Remove the PC Card cage by pulling it to the right and twisting slightly toward you.
    Спросите у FixBot
  27. PowerBook G4 Titanium Onyx Upper Case Replacement, Display: шаг 28, изображение 1 из 1
    • Performing the following steps incorrectly can easily damage the display and render it inoperable. The multicolored display data cable is especially fragile.
    • Remove the four black T8 Torx screws from the plastic framework.
    Спросите у FixBot
  28. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 29, изображение 1 из 1
    • Remove the five silver T8 Torx screws from the metal framework.
    Спросите у FixBot
  29. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 30, изображение 1 из 1
    • Turn the G4 over.
    • Grasp the plastic framework and pull directly up.
    Спросите у FixBot
  30. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 31, изображение 1 из 1
    • Position the display at a 45 degree angle and rest the computer on a soft cloth with the back panel ports facing up.
    • Remove the two T8 Torx screws from each clutch cover.
    Спросите у FixBot
  31. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 32, изображение 1 из 1
    • Close the display and pull off both clutch covers. You can use a non-metal flathead screwdriver if the clutch covers do not come off easily.
    Спросите у FixBot
  32. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 33, изображение 1 из 1
    • Open the back panel port cover and remove the four T6 Torx screws.
    • The upper screw on each side fastens a small metal mount in place. Be sure to put this part back in when reassembling the computer.
    Спросите у FixBot
  33. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 34, изображение 1 из 1
    • Disconnect the audio cable at the right side of the computer, removing tape as necessary.
    Спросите у FixBot
  34. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 35, изображение 1 из 1
    • Open the display to a 90 degree angle. Rest the trackpad face down on the work surface and allow the display to hang over the edge. If possible, adjust your chair or work surface height so the display will rest on your legs and the trackpad will lie flat on the work surface.
    • Remove the four T8 Torx screws that fasten the display to the trackpad. The screw closest to the display data cable has a tapered head.
    Спросите у FixBot
  35. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 36, изображение 1 из 1
    • Grasp the metal heat exchanger and pull up and away from you. You may need to move the inverter cable on the right side of the computer in order to rotate the heat exchanger.
    Спросите у FixBot
  36. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 37, изображение 1 из 1
    • Lift up the metal brackets on either side of the upper case.
    Спросите у FixBot
  37. PowerBook G4 Titanium Onyx Upper Case Replacement: шаг 38, изображение 1 из 1
    • Disconnect the inverter cable and carefully thread it through the slot in the upper case.
    • Carefully thread the display and backlight cables individually through the slot in the upper case. Be very careful with the display cable as it is easily damaged.
    • Remove the display assembly.
    Спросите у FixBot
  38. PowerBook G4 Titanium Onyx Upper Case Replacement, Inverter Board: шаг 39, изображение 1 из 1
    • Lift the inverter board out of the computer.
    Спросите у FixBot
  39. PowerBook G4 Titanium Onyx Upper Case Replacement, Upper Case: шаг 40, изображение 1 из 1
    • Upper case remains.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Прикрепленные документы
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 52
За всё время: 8,343
