Введение
If your device isn't working and other troubleshooting methods have failed, or a component of the motherboard has failed, use this guide to replace the motherboard and make your device functional again.
Выберете то, что вам нужно
Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
With the soldering tool remove the speaker wires, battery wires and gray wire that are connected to the motherboard.
Use a PH00 screw driver to remove the three 4 mm screws holding the motherboard down.
2 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Once the motherboard is out, what do you do ? Where do I go? More information would be appreciated.
