Выберете то, что вам нужно
Unscrew the two screws that are holding the lamp in place.
Pull the lamp out.
Remove 5 screws from the bottom.
Remove 1 screw from the back.
Slowly lift the upper housing and disconnect the connector.
After removing the upper housing. Turn the projector to see the fan.
Unscrew two screws from each side of the fan holder.
Remove the fan from holder by unscrewing the two screws.
Еще один человек закончил это руководство.
