Введение
Repeated dropping and use of your tablet can result in damaging various physical and electrical components like the camera. If your device's camera is malfunctioning, follow this guide to access and replace it.
Выберете то, что вам нужно
Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
Use the flat end of the spudger to gently pry the top left corner battery from the back of the screen in order to access the camera.
Use the spudger to lift the black clamp as shown in the photo to disconnect the camera from the motherboard.
Disconet the camera from the motherboard.
Pull the camera from the back of the screen.
Еще один человек закончил это руководство.
