Protocol Slipstream WiFi Camera Replacement
Выберете то, что вам нужно
  1. Protocol Slipstream WiFi Camera Replacement, Camera: шаг 1, изображение 1 из 2 Protocol Slipstream WiFi Camera Replacement, Camera: шаг 1, изображение 2 из 2
    • Remove the four 5.5 mm Phillips #00 screws that hold the lower canopy to the upper canopy.
    • Gently pull the lower canopy up and towards the back of the drone. The lower canopy will still be attached to the upper canopy by 3 wires. Just set the lower canopy aside and continue with the repair.
    • Be very careful when pulling the lower canopy apart from the upper canopy. There are 3 wires that will still be attached between the lower and upper canopies.
    Спросите у FixBot
    Добавить комментарий
  2. Protocol Slipstream WiFi Camera Replacement: шаг 2, изображение 1 из 2 Protocol Slipstream WiFi Camera Replacement: шаг 2, изображение 2 из 2
    • Remove the four 5.5 mm Phillips #00 screws that holds the battery tray to the lower canopy.
    • Once the four 5.5 mm Philips #00 screws are removed gently pull on the battery tray to separate it from the lower canopy.
    Спросите у FixBot
  3. Protocol Slipstream WiFi Camera Replacement: шаг 3, изображение 1 из 1
    • Use a spudger to gently pry around the outside edge of the camera to remove the camera from its mounting hole.
    • Be careful when removing the camera from its mounting hole as there is a small ribbon wire that connects it to the computer.
    • The camera and computer assembly will now be free to move. Move the lower canopy out of the way for now.
    Спросите у FixBot
  4. Protocol Slipstream WiFi Camera Replacement: шаг 4, изображение 1 из 3 Protocol Slipstream WiFi Camera Replacement: шаг 4, изображение 2 из 3 Protocol Slipstream WiFi Camera Replacement: шаг 4, изображение 3 из 3
    • Use the flat side of the spudger and push the 2 tabs on either side of the camera connection on the computer and push the tabs towards the front of the drone (away from the computer).
    • Make sure both tabs are all the way out otherwise the ribbon wire for the camera will not be free and you can damage the wire by pulling on it.
    • Now remove the camera ribbon wire from the camera connection on the computer.
    Спросите у FixBot
Заключение
John Burkee
Участник с: 09/17/19
445 Репутация
Автор 4 руководств
Команда
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 32
За всё время: 453
