RCA 8 Apollo Screen Replacement
Выберете то, что вам нужно
  1. RCA 8 Apollo Screen Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
    Спросите у FixBot
    Добавить комментарий
  2. RCA 8 Apollo Screen Replacement: шаг 2, изображение 1 из 2 RCA 8 Apollo Screen Replacement: шаг 2, изображение 2 из 2
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
    Спросите у FixBot
  3. RCA 8 Apollo Screen Replacement: шаг 3, изображение 1 из 2 RCA 8 Apollo Screen Replacement: шаг 3, изображение 2 из 2
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
    Спросите у FixBot
  4. RCA 8 Apollo Screen Replacement, Display Assembly: шаг 4, изображение 1 из 3 RCA 8 Apollo Screen Replacement, Display Assembly: шаг 4, изображение 2 из 3 RCA 8 Apollo Screen Replacement, Display Assembly: шаг 4, изображение 3 из 3
    • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
    • Remove the yellow tape that is around the battery.
    • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
    • If the connector is misaligned, the pins can bend, causing permanent damage.
    Спросите у FixBot
  5. RCA 8 Apollo Screen Replacement: шаг 5, изображение 1 из 1
    • Remove the three screws from the motherboard using a Phillips screwdriver.
    Спросите у FixBot
  6. RCA 8 Apollo Screen Replacement: шаг 6, изображение 1 из 1
    • Remove the battery and motherboard together from the tablet.
    • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
    • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
    Спросите у FixBot
  7. RCA 8 Apollo Screen Replacement, Screen: шаг 7, изображение 1 из 3 RCA 8 Apollo Screen Replacement, Screen: шаг 7, изображение 2 из 3 RCA 8 Apollo Screen Replacement, Screen: шаг 7, изображение 3 из 3
    • Remove the screw from the bottom left of the tablet.
    • Place an opening tool under the screen.
    • Pry up the screen and it will unclip from the clips holding the screen down.
    • Avoid using too much force to prevent the glass from breaking.
    Спросите у FixBot
Заключение
McKenna Shipper
Участник с: 04/12/24
123 Репутация
1 руководство автора
Команда
Casper College, Team 1-1, Lareau Spring 2024 Участник Casper College, Team 1-1, Lareau Spring 2024
CASC-LAREAU-S24S1G1
3 членов
Автор 4 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 249
