RCA RCT6077W2 LCD Replacement
Выберете то, что вам нужно
    1. RCA RCT6077W2 LCD Replacement, Backplate: шаг 1, изображение 1 из 2 RCA RCT6077W2 LCD Replacement, Backplate: шаг 1, изображение 2 из 2
      • Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
      Спросите у FixBot
      Добавить комментарий
    2. RCA RCT6077W2 LCD Replacement: шаг 2, изображение 1 из 2 RCA RCT6077W2 LCD Replacement: шаг 2, изображение 2 из 2
      • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
      • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
      • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
      Спросите у FixBot
    1. RCA RCT6077W2 LCD Replacement, Battery, Motherboard, Speaker, and Antenna: шаг 3, изображение 1 из 1
      • Remove the battery by first removing the electrical tape holding it down. Then begin gently prying underneath it and around the edges with your plastic opening tool, until the battery is loose.
      Спросите у FixBot
    2. RCA RCT6077W2 LCD Replacement: шаг 4, изображение 1 из 1
      • Remove the antenna by peeling back the tape holding the antenna to the casing.
      Спросите у FixBot
    3. RCA RCT6077W2 LCD Replacement: шаг 5, изображение 1 из 2 RCA RCT6077W2 LCD Replacement: шаг 5, изображение 2 из 2
      • Unclip the ribbon cables from the motherboard by lifting up on their latches (the black portions that the cables feed into) and gently pulling the cables.
      • Do not use force to try and remove the cables. The latch may not be lifted up all the way, and using force can separate the cable from its connector. This can damage important components of the tablet.
      Спросите у FixBot
    4. RCA RCT6077W2 LCD Replacement: шаг 6, изображение 1 из 2 RCA RCT6077W2 LCD Replacement: шаг 6, изображение 2 из 2
      • Remove the three 2.5mm Phillips screws from the motherboard.
      • After removing the screws, use a plastic opening tool to gently pull the motherboard off of the double-sided tape holding it down.
      Спросите у FixBot
    5. RCA RCT6077W2 LCD Replacement: шаг 7, изображение 1 из 1
      • Replace the removed unit with a suitable replacement, with all of the pictured parts.
      • When reassembling the device, be sure to put the speaker back into its slot in the casing before securing the backplate.
      Спросите у FixBot
    1. RCA RCT6077W2 LCD Replacement, LCD: шаг 8, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      Plastic Cards
      $2.99
      • To remove the LCD from the screen casing, gently pry it out of the clips that are holding it in place.
      • Try and focus on one half of the LCD, as the other half will come out easily when the first half comes loose. Be careful not to damage the clips that hold the LCD in place. Also be careful not to damage the LCD housing by prying underneath it. Use plastic cards to keep clips from reattaching themselves to the device to help in its removal.
      Спросите у FixBot
    2. RCA RCT6077W2 LCD Replacement: шаг 9, изображение 1 из 1
      • This is the component once it is removed from the screen casing.
      Спросите у FixBot
Заключение
6 человек успешно провели ремонт по этому руководству.
Ryan Williams
Участник с: 01/27/15
1 157 Репутация
Автор 4 руководств
Команда
Pasco Hernando, Team 1-2, Prince Winter 2015 Участник Pasco Hernando, Team 1-2, Prince Winter 2015
PHSC-PRINCE-W15S1G2
6 членов
Автор 8 руководств
1 Комментарий к руководству
This was no help at all. What do you do after the final step? Where do I get a replacement LCD screen for this tablet?
I would really love to get a response soon, please. Thank you!
Juan Ramirez Jr - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 2,215
