RCA RCT6203W46 Rear Camera Replacement
Выберете то, что вам нужно
    1. RCA RCT6203W46 Rear Camera Replacement, Front and Rear Camera: шаг 1, изображение 1 из 2 RCA RCT6203W46 Rear Camera Replacement, Front and Rear Camera: шаг 1, изображение 2 из 2
      • Make sure the device is off to reduce the chance of an electrical shock. To turn off the device, press and hold the power button.
      • Use a Phillips #00 Screwdriver to unscrew the 4mm (5/32 in.) screws from the back cover of the tablet.
      Спросите у FixBot
      Добавить комментарий
    2. RCA RCT6203W46 Rear Camera Replacement: шаг 2, изображение 1 из 2 RCA RCT6203W46 Rear Camera Replacement: шаг 2, изображение 2 из 2
      • Use a spudger to pry the back cover. Start from one edge of the back cover and slide across until the cover is lifted from the tablet body. Repeat for all edges.
      Спросите у FixBot
    3. RCA RCT6203W46 Rear Camera Replacement: шаг 3, изображение 1 из 1
      • Open the tablet cover carefully and slowly lengthwise.
      • The keyboard wire ribbon and rear speaker wire should be intact and connected with the back cover.
      • Opening the tablet abruptly may tear or damage cover attachments.
      Спросите у FixBot
    4. RCA RCT6203W46 Rear Camera Replacement: шаг 4, изображение 1 из 1
      • Use a spudger to flip up the flap of the ZIF connector that holds the keyboard wire ribbon.
      • Remove the wire ribbon from clamp.
      Спросите у FixBot
    5. RCA RCT6203W46 Rear Camera Replacement: шаг 5, изображение 1 из 2 RCA RCT6203W46 Rear Camera Replacement: шаг 5, изображение 2 из 2
      • Attached to the motherboard you will see two orange ribbons connected to black tabs.
      • Using both hands, place your thumbs gently on the black tab attached to the top and gently lift it.
      • Proceed to slide the orange colored ribbon out from underneath until it is detached from the black tab.
      Спросите у FixBot
    6. RCA RCT6203W46 Rear Camera Replacement: шаг 6, изображение 1 из 1
      • Use a spudger to pry and slide underneath the battery to unstick it from the LCD metal plate. It may take a good amount of force to remove.
      • Try to decrease battery deformation by using a spudger rather than prying with your hands.
      • Do not let battery fall back on adhesive, it will stick back onto the LCD metal plate.
      • Be careful to not puncture the battery. The battery may ignite or explode.
      Спросите у FixBot
    7. RCA RCT6203W46 Rear Camera Replacement: шаг 7, изображение 1 из 2 RCA RCT6203W46 Rear Camera Replacement: шаг 7, изображение 2 из 2
      • Gently remove the grey tape that's covering the grey colored wire until it is completely peeled off.
      • Peel off the black piece of tape to remove the antenna.
      Спросите у FixBot
    8. RCA RCT6203W46 Rear Camera Replacement: шаг 8, изображение 1 из 1
      • Unscrew three of the 4 mm screws on the motherboard using a Phillips #00 screwdriver.
      • After removing the screws, detach the motherboard from the rest of the tablet. Use a spudger to gently remove it, if necessary.
      Спросите у FixBot
    9. RCA RCT6203W46 Rear Camera Replacement: шаг 9, изображение 1 из 1
      • Locate the rear camera and use a prying tool to gently lift the rear camera off of the motherboard.
      Спросите у FixBot
    10. RCA RCT6203W46 Rear Camera Replacement: шаг 10, изображение 1 из 1
      • Detach the camera ribbon wire by lifting the tab and pulling the wire. This will leave you with the camera assembly.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Grace Chung
Участник с: 09/21/16
212 Репутация
1 руководство автора
Команда
UC Davis, Team 1-2, Oliver Fall 2016 Участник UC Davis, Team 1-2, Oliver Fall 2016
UCD-OLIVER-F16S1G2
5 членов
Автор 8 руководств
1 Комментарий к руководству
Where can I get the main board from RCT6203W46
top - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 31
За всё время: 623
