Razor A Wheel Replacement
Выберете то, что вам нужно
    1. Razor A Wheel Replacement, Wheel: шаг 1, изображение 1 из 1
      • Flip the scooter upside-down with the handlebars and brake on the ground.
      Спросите у FixBot
      Добавить комментарий
    2. Razor A Wheel Replacement: шаг 2, изображение 1 из 2 Razor A Wheel Replacement: шаг 2, изображение 2 из 2
      • Grab two 3/16" Allen wrenches. Insert one in each screw on the sides of the wheel. Hold one screw in place while turning the other in a counter-clockwise direction, loosening the screw.
      • Once both screws are removed the wheel should be free and fall out.
      • One of the screws fits inside the other. The inner screw should be 5.6 mm in length. During reassembly, the screws can be put back in on either side.
      • During reassembly, do not over-tighten the screws, as you could strip them. They should be just tight enough to prevent the wheel from wobbling.
      Спросите у FixBot
    3. Razor A Wheel Replacement: шаг 3, изображение 1 из 2 Razor A Wheel Replacement: шаг 3, изображение 2 из 2
      • When replacing a wheel, look for a metal sleeve in the center of the bearing that may be out of line. Forcing a screw through a sleeve that is out of line could ruin the wheel.
      • Remove any obstructions inside the bearing of the new wheel, and move the inner sleeve in the bearing with an Allen key so that the screws can slide into the bearing freely.
      • Put the replacement wheel into place in the scooter frame.
      • For extra security, you can add a small amount of threadlocker glue to the the bolt and tighten it just until until it doesn't fall off or lock the wheel.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Jordyn
Участник с: 10/09/12
565 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 9-13, Amido Fall 2012 Участник Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 членов
Автор 15 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 23
За последние 30 дней: 97
За всё время: 14,316
