Введение
Screen and / or digitizer are broken but the rest of the phone is still fully functional.
Выберете то, что вам нужно
Remove the upper speaker
Caution: When removing the speaker, the two parts of the speaker can separate from each other. They are only held together by two very thin copper cables!
The best way to get to the bottom of the speaker and pry it out carefully is by using the direction of the red arrow.
For testing purposes, the button bar, the screen and the battery can be connected.
Attention! When doing so, there is an increased risk of damaging the connections or the battery. Be very careful!
A long press on the bottom button should start the phone
Remove the cover from the two adhesive strips for the battery
Insert the battery and reconnect it.
Repeat the steps in reverse order to reassemble your device.
5 человек успешно провели ремонт по этому руководству.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
3 Комментарии к руководству
There are major steps missing between step 14 and step 15. This is not a complete guide on screen replacement.
Hi Don, which steps are you missing between 14 and 15 ? Once all parts are removed from the old display one can try the test fit on the new display.
Watch and pray ,global warming.
