Remote shutter mod (wired)
Выберете то, что вам нужно
    • I will hopefully add more details in the future.
    Спросите у FixBot
    Добавить комментарий
  1. Remote shutter mod (wired), Solder a wire onto a main board: шаг 2, изображение 1 из 3 Remote shutter mod (wired), Solder a wire onto a main board: шаг 2, изображение 2 из 3 Remote shutter mod (wired), Solder a wire onto a main board: шаг 2, изображение 3 из 3
    • Use thin short piece of wire and decide where to put it so it will not be in interference with other components inside assembled camera. The wire will be connected to both sides of the main board.
    • Cut required length of the wire and cut the insulation on its ends.
    • Optional: use some electrical adhesive tape (not very sticky) to hold the wire on the right place while soldering. Watch where are you putting it - not over any small sensitive components
    • Solder the wire to the pins as on the pictures
    Спросите у FixBot
    • Insert the modified mainboard, put everything to its place and close the camera. Simply reverse the disassembly procedure
    Спросите у FixBot
  2. Remote shutter mod (wired), Create your custom shutter connector: шаг 4, изображение 1 из 3 Remote shutter mod (wired), Create your custom shutter connector: шаг 4, изображение 2 из 3 Remote shutter mod (wired), Create your custom shutter connector: шаг 4, изображение 3 из 3
    • Use some standard micro USB male connector/cable
    • You can connect some remote shutter to it, or just a button which allows the lines to connect.
    • Pinout as is on the picture
    • sorry for the drawing of microUSB, it looks like half female (because of the inside) and half male. It's supposed to be male connector. But the positions of the pins are correct.
    Спросите у FixBot
Заключение
I am not author of the mod, but I will definitely try it in the future.
Pictures are taken from here:
http://przewodnicy.zakopane.pl/rozne/RX1...
Short demonstration is visible here:
https://www.youtube.com/watch?v=3m_yFcxR...
Unfortunately I don't have an option to use any soldering iron or my small tools at the moment, so I will not try it during this year (2017). But it's good to have this guide here.
Matej Cermak
Участник с: 10/22/17
109 Репутация
1 руководство автора
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 57
За всё время: 3,613
