Removing Solid-State Drive (SSD) shielding
Выберете то, что вам нужно
    1. Removing Solid-State Drive (SSD) shielding, Remove screws from bottom of laptop.: шаг 1, изображение 1 из 2 Removing Solid-State Drive (SSD) shielding, Remove screws from bottom of laptop.: шаг 1, изображение 2 из 2
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      Спросите у FixBot
      Добавить комментарий
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      Спросите у FixBot
    1. Removing Solid-State Drive (SSD) shielding, Disconnect battery cable: шаг 3, изображение 1 из 1
      • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
      • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
      Спросите у FixBot
    1. Removing Solid-State Drive (SSD) shielding, Remove the system board mylar: шаг 4, изображение 1 из 2 Removing Solid-State Drive (SSD) shielding, Remove the system board mylar: шаг 4, изображение 2 из 2
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
      Спросите у FixBot
    1. Removing Solid-State Drive (SSD) shielding, Remove the solid-state drive (SSD) shielding: шаг 5, изображение 1 из 1
      • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      Спросите у FixBot
Заключение
johann beda
Участник с: 09/13/10
3 428 Репутация
Автор 15 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 27
За всё время: 124
