Removing System board
Выберете то, что вам нужно
Рекомендуемый документ
Предварительный просмотр первой страницы этого документа
Lenovo Legion 9 16irx9 Hmm
Войдите, чтобы посмотреть полный текст документа
Войти
    1. Removing System board, Remove screws from bottom of laptop.: шаг 1, изображение 1 из 2 Removing System board, Remove screws from bottom of laptop.: шаг 1, изображение 2 из 2
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      Спросите у FixBot
      Добавить комментарий
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      Спросите у FixBot
    1. Removing System board, Disconnect battery cable: шаг 3, изображение 1 из 1
      • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
      • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
      Спросите у FixBot
    1. Removing System board, Remove battery screws: шаг 4, изображение 1 из 1
      • Remove 6 black 4mm PH1 screws (M2 x L4). The lower right screw is close to a magnet that may pull it from where you want it to go - tweezers may be necessary. The Hardware Maintenance Manual does not show the bottom middle screw.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      Спросите у FixBot
      • Lift out the battery.
      Спросите у FixBot
    1. Removing System board, Remove the system board mylar: шаг 6, изображение 1 из 2 Removing System board, Remove the system board mylar: шаг 6, изображение 2 из 2
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
      Спросите у FixBot
    1. Removing System board, Remove the solid-state drive (SSD) shielding: шаг 7, изображение 1 из 1
      • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
      Спросите у FixBot
    1. Removing System board, Unscrew Solid-State Drives (SSD): шаг 8, изображение 1 из 1
      • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
      Спросите у FixBot
      • Remove each SSD by pulling it away from the slot.
      • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
      Спросите у FixBot
    1. Removing System board, Remove the Wi-Fi card: шаг 10, изображение 1 из 1
      • Detach the main and auxiliary antenna cable connectors. Note which colour cable is connected to each post - the photographed board has a grey cable connected to the top post (marked as "#1 Aux" with a white triangle on the Wi-Fi card) and a black cable connected to the bottom post (marked as "#2 Main" with a black triangle on the Wi-Fi card).
      • Remove 1 silver 2mm PH1 screw (M2 x L2).
      • Remove the Wi-Fi card by pulling it away from the slot.
      Спросите у FixBot
    1. Removing System board, Disconnect tape and cables: шаг 11, изображение 1 из 1
      • (1) Peel off the thermal DIMM plate tape from the system board.
      • (2-3) Lift flap and disconnect the I/O board cable from the system board.
      • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
      • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
      • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
      Спросите у FixBot
    2. Removing System board, Disconnect the fan cables: шаг 12, изображение 1 из 1
      • Disconnect the three fan cables from the system board by lifting away from board.
      Спросите у FixBot
    3. Removing System board, Remove screws and fans: шаг 13, изображение 1 из 1
      • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
      • Remove tape from fans - possibly using gentle heat
      • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
      Спросите у FixBot
    1. Removing System board, Disconnect cables: шаг 14, изображение 1 из 1
      • Disconnect 9 cables connected to the system board.
      Спросите у FixBot
    2. Removing System board, Disconnect more cables: шаг 15, изображение 1 из 1
      • Disconnect five more cables from the system board
      Спросите у FixBot
      • Remove 3 black 4mm PH1 screws (M2 x L4) screws
      • Remove 2 black 6mm PH1 screws (M2 x L4) screws
      • Remove the flaps of tape holding the antenna wires to the board.
      • Remove the system board module carefully.
      Спросите у FixBot
Заключение
Прикрепленные документы
johann beda
Участник с: 09/13/10
3 428 Репутация
Автор 15 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 112
