Removing fans
Выберете то, что вам нужно
    1. Removing fans, Remove screws from bottom of laptop.: шаг 1, изображение 1 из 2 Removing fans, Remove screws from bottom of laptop.: шаг 1, изображение 2 из 2
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      Спросите у FixBot
      Добавить комментарий
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      Спросите у FixBot
    1. Removing fans, Remove the system board mylar: шаг 3, изображение 1 из 2 Removing fans, Remove the system board mylar: шаг 3, изображение 2 из 2
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
      Спросите у FixBot
    1. Removing fans, Disconnect tape and cables: шаг 4, изображение 1 из 1
      • (1) Peel off the thermal DIMM plate tape from the system board.
      • (2-3) Lift flap and disconnect the I/O board cable from the system board.
      • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
      • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
      • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
      Спросите у FixBot
    2. Removing fans, Disconnect the fan cables: шаг 5, изображение 1 из 1
      • Disconnect the three fan cables from the system board by lifting away from board.
      Спросите у FixBot
    3. Removing fans, Remove screws and fans: шаг 6, изображение 1 из 1
      • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      • Remove tape from fans - possibly using gentle heat
      • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
      Спросите у FixBot
Заключение
johann beda
Участник с: 09/13/10
3 428 Репутация
Автор 15 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 35
За всё время: 140
