Введение
Canon "E-18 error" happens when the lens gets stuck in the extended position. The LCD will display a little E-18 in the lower-left corner and start beeping.
Выберете то, что вам нужно
Place camera lens facing upwards on the table.
Press and hold down the power button.
Simultaneously press down the shutter button.
Replace the batteries in the camera.
Remove the old batteries from the camera and wait a few moments.
Put in a fresh set of batteries.
Close battery slide and power camera back on.
Put blow dryer in the "no heat" setting prior to plugging it in.
Plug in and turn the blow dryer on.
Blow air in the gaps between the lens.
In conclusion, using this guide to fix the E-18 on the lens of the Canon PowerShot A80,will allow the camera to capture photos once again. To reassemble your device, follow these instructions in reverse order.
2 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
merci! mon appareil fonctionne à nouveau
