Введение
Elastic bands wear out over time and also tend to lose their elasticity due to frequent washing as the softeners dissolve. Luckily, a new rubber band is easy to move in, you only need needles, thread, a pair of scissors, a new elastic band and a little patience.
Выберете то, что вам нужно
Measure the new rubber band to the appropriate length. To do this, put the rubber band around the waist or waist and stretch slightly.
The rubber band must be adjusted so that the garment later has enough tension to not slip.
Then add 1-5 cm seam allowance and cut.
Uncover the old rubber band. To do this, carefully cut the seam in an inconspicuous area on the inside of the waistband with the scissors or the seam splitter so that the fabric is not damaged.
Grasp the old rubber band with the point of the scissors or with your fingers and pull it out a little bit.
Now cut the old rubber band.
As soon as the knot becomes visible at the beginning of the new rubber band, the knot can be loosened and the old rubber band can be used for textile recycling or for tying tomatoes :-)
Now put the two ends of the new elastic band together so that they overlap 1-5 centimeters according to the seam allowance.
If both edges are sewn together, do not completely pull through the thread at the last stitch, but catch the forming loop with your finger.
Insert the needle into the loop and pull it through.
Now pull the thread tight so that the loop closes and a knot is formed.
Cut off the protruding thread and stow the needle and the remaining thread safely for the next time ;-)
Now stretch the waistband so far that the elastic band gradually disappears into the waistband due to the tension.
If you like, you can now sew up the opening that you might have had to tie in the beginning with a few stitches, we leave this unobtrusive opening open for a possible later replacement of the rubber band.
FINISHED! And so quickly your waistband has the necessary elasticity!
3 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
