Replacing Creative Zen X-Fi Speaker
Выберете то, что вам нужно
    1. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: шаг 1, изображение 1 из 3 Replacing Creative Zen X-Fi Speaker, Detaching Front Case: шаг 1, изображение 2 из 3 Replacing Creative Zen X-Fi Speaker, Detaching Front Case: шаг 1, изображение 3 из 3
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      Спросите у FixBot
      Добавить комментарий
    1. Replacing Creative Zen X-Fi Speaker, Rubber Button Cover: шаг 2, изображение 1 из 1
      • The black rubber button pad can be removed by simply picking it up.
      Спросите у FixBot
    1. Replacing Creative Zen X-Fi Speaker, Button Input Chip Part 1: шаг 3, изображение 1 из 1
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      Спросите у FixBot
    2. Replacing Creative Zen X-Fi Speaker, Button Input Chip: шаг 4, изображение 1 из 1
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      Спросите у FixBot
    1. Replacing Creative Zen X-Fi Speaker, Access Midsection Plate: шаг 5, изображение 1 из 1
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      Спросите у FixBot
    2. Replacing Creative Zen X-Fi Speaker, Unscrew below Button Chip: шаг 6, изображение 1 из 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      Спросите у FixBot
    3. Replacing Creative Zen X-Fi Speaker, Unscrew below LCD Screen: шаг 7, изображение 1 из 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      Спросите у FixBot
    1. Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: шаг 8, изображение 1 из 2 Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: шаг 8, изображение 2 из 2
      • Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case.
      • Once unscrewed, pick up the case and put it to the side.
      Спросите у FixBot
    2. Replacing Creative Zen X-Fi Speaker, Removing the Speaker: шаг 9, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Westley Courchene
Участник с: 01/13/15
3 410 Репутация
Автор 14 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 46
За всё время: 753
