Ridgid R86034 Direction Switch Replacement
Выберете то, что вам нужно
    1. Ridgid R86034 Direction Switch Replacement, Housing: шаг 1, изображение 1 из 1
      • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
      • Use some force; the rubber cover is securely attached to the housing.
      • Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
      • Make sure the casing is properly oriented onto the housing. Orientation is important here.
      Спросите у FixBot
      Добавить комментарий
    2. Ridgid R86034 Direction Switch Replacement: шаг 2, изображение 1 из 2 Ridgid R86034 Direction Switch Replacement: шаг 2, изображение 2 из 2
      • Remove the plastic cover with your hands. It should come off fairly easily.
      Спросите у FixBot
    3. Ridgid R86034 Direction Switch Replacement: шаг 3, изображение 1 из 3 Ridgid R86034 Direction Switch Replacement: шаг 3, изображение 2 из 3 Ridgid R86034 Direction Switch Replacement: шаг 3, изображение 3 из 3
      • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
      • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
      Спросите у FixBot
    4. Ridgid R86034 Direction Switch Replacement: шаг 4, изображение 1 из 2 Ridgid R86034 Direction Switch Replacement: шаг 4, изображение 2 из 2
      • Unscrew the eight 15 mm T10 Torx screws from the housing
      • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
      Спросите у FixBot
    5. Ridgid R86034 Direction Switch Replacement: шаг 5, изображение 1 из 1
      • Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
      • Pry apart the two halves of the housing at the back side of the driver using the metal spudger. The housing is easier to remove if you pry from both sides.
      Спросите у FixBot
    6. Ridgid R86034 Direction Switch Replacement: шаг 6, изображение 1 из 2 Ridgid R86034 Direction Switch Replacement: шаг 6, изображение 2 из 2
      • Do not remove the direction switch.
      • Pull out all electrical components from housing by hand. The components should require little force to lift out.
      • Lift out the motor.
      • Follow the wires.
      • The circuit board located nearest the battery pack and the LED light will be hard to pull out.
      • Remember to precisely place all components in their correct slots with their correct orientations when reassembling.
      Спросите у FixBot
    1. Ridgid R86034 Direction Switch Replacement, Direction Switch: шаг 7, изображение 1 из 1
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Sean Liston
Участник с: 04/28/15
311 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 15-5, Amido Spring 2015 Участник Cal Poly, Team 15-5, Amido Spring 2015
CPSU-AMIDO-S15S15G5
4 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 40
За всё время: 2,265
