Ryobi D620H Motor Brush Replacement
Выберете то, что вам нужно
    1. Ryobi D620H Motor Brush Replacement, Right Side Case Removal: шаг 1, изображение 1 из 1
      • Turn the drill so that the screws face upwards.
      • Use the Torx T20 screwdriver to remove all nine screws.
      Спросите у FixBot
      Добавить комментарий
    2. Ryobi D620H Motor Brush Replacement: шаг 2, изображение 1 из 2 Ryobi D620H Motor Brush Replacement: шаг 2, изображение 2 из 2
      • Insert the end of an opening tool between the right and left sides of the drill to pry the right side of the case.
      • Remove the right side case to expose the inside of the drill.
      Спросите у FixBot
    1. Ryobi D620H Motor Brush Replacement, Motor Brush: шаг 3, изображение 1 из 1
      • The motor brushes are located on the rotating armature of the motor.
      • Look for the large dark gray metal housing in the center of the body of the drill, this is the motor.
      • The armature of the motor by finding the chuck and the transfer gears, and then look at the other end of the motor. There is a small copper barrel (armature) that is likely colored dark gray from the carbon brushes rubbing against the armature.
      • On the top and bottom of the armature (small copper barrel), there are brass spring-loaded brackets holding blocks of carbon against the armature; these blocks are the motor brushes.
      Спросите у FixBot
    2. Ryobi D620H Motor Brush Replacement: шаг 4, изображение 1 из 2 Ryobi D620H Motor Brush Replacement: шаг 4, изображение 2 из 2
      • Unscrew the brass spring-loaded bracket from the case using a PH1 screwdriver and remove them from the case and armature.
      • The motor brush will likely partialy self-eject from the brass brackets.
      • It is highly recommended to replace one motor brush at a time to not mix up the wiring.
      • Unscrewing the brush brackets is the same for both top and bottom.
      Спросите у FixBot
    3. Ryobi D620H Motor Brush Replacement: шаг 5, изображение 1 из 1
      • Pull the two connections (circled in red) gently from their terminals.
      • The longer white wire connects to the left side terminal and the shorter white wire connected to the brush connects to the right side terminal
      • Remove the composite shim under the bracket.
      Спросите у FixBot
    4. Ryobi D620H Motor Brush Replacement: шаг 6, изображение 1 из 1
      • Remove screws and disconnect the two terminals circled in red on the bottom brush bracket.
      • Remove the longer black wire that connects to the left side terminal
      • Remove the shorter white wire connected to the brush that connects to the right side terminal
      • Remove composite shim under the bracket.
      Спросите у FixBot
    5. Ryobi D620H Motor Brush Replacement: шаг 7, изображение 1 из 2 Ryobi D620H Motor Brush Replacement: шаг 7, изображение 2 из 2
      • This process is identical for the top and bottom brushes as they are mirrored.
      • Remove the right-side wire from terminal. (The wire that connects to the brush).
      • Pull the brush out of the brackets gently. It shouldn't require much force.
      Спросите у FixBot
    6. Ryobi D620H Motor Brush Replacement: шаг 8, изображение 1 из 2 Ryobi D620H Motor Brush Replacement: шаг 8, изображение 2 из 2
      • Place the new coil spring on the new bracket.
      • Slide the motor brush wire into the bracket and connect it to the right-side terminal.
      • Reconnect the longer white wire on the top brackets left side terminal by firmly and steadily pushing down.
      • Reconnect the longer black wire on the bottom bracket left side terminal by firmly and steadily pushing down.
      • Replace the composite shim under the brackets.
      • Screw both brackets down.
      Спросите у FixBot
Заключение
You've successfully replaced the motor brushes on your Ryobi Hammer Drill!
Еще один человек закончил это руководство.
Jacob da Ponte
Участник с: 10/30/23
469 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team 1-2, Petersen Fall 2023 Участник UMass Dartmouth, Team 1-2, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G2
4 членов
Автор 6 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 83
За всё время: 1,388
