Введение
Use this guide to help replace the Ryobi RS290G Sander motor. The Ryobi RS290G uses a 2.6 AMP motor and 12,500 OPM (orbits per minute).
If you ordered the correct part, it should have the disconnect terminals already installed/crimped on.
Through out its use the motor may experience some damage, be faulty, and can eventually become unusable all together. With this guide, it can teach you how to salvage your Ryobi RS290G Sander and completely replace its old motor.
This is a pretty simple replacement and does not require much specialty skills. Have fun with it and enjoy your Ryobi RS290G sander.
Выберете то, что вам нужно
Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
Slide off the disconnect terminal for the switch (red lead) from the power switch using the flat end of a spudger.
Slide out the brush assembly with the black lead from the inner housing assembly.
Slide off the disconnect terminal for the brush assembly (black lead) from the brush assembly.
Remove the armature assembly, with the motor, out of the inner housing assembly.
