Введение
Use the guide below to replace the battery for the Samsung Chromebook Pro.
Выберете то, что вам нужно
Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
Slide the plastic opening tool in a corner at a steep angle, and lift to remove the outer case.
Remove the four 30 mm screws surrounding the battery with the JIS J000 screw bit.
Инструмент, используемый на этом этапе:Tweezers$4.99
Lift the connecting wires to disconnect from the slot with the precision tweezers.
Lift battery to remove once the wire is disconnected.
4 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
How do I know which battery to order? Is there a specific part number?
