Samsung Droid Charge SIM Card Port Replacement
Выберете то, что вам нужно
  1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: шаг 1, изображение 1 из 1
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
    Спросите у FixBot
    Добавить комментарий
  2. Samsung Droid Charge SIM Card Port Replacement, Battery: шаг 2, изображение 1 из 1
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
    Спросите у FixBot
  3. Samsung Droid Charge SIM Card Port Replacement, microSD: шаг 3, изображение 1 из 1
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
    Спросите у FixBot
  4. Samsung Droid Charge SIM Card Port Replacement, SIM Card: шаг 4, изображение 1 из 1
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
    Спросите у FixBot
  5. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: шаг 5, изображение 1 из 1
    • Carefully remove the back cover.
    • Remove the two 5mm screws with a small Phillips head screwdriver.
    Спросите у FixBot
  6. Samsung Droid Charge SIM Card Port Replacement: шаг 6, изображение 1 из 1
    • Removal of the back half of the casing.
    • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
    • Use a prying motion to lift the casing up. This will separate the phone casing.
    • Repeat this motion all around the screen edge until the casing pops off.
    Спросите у FixBot
  7. Samsung Droid Charge SIM Card Port Replacement: шаг 7, изображение 1 из 1
    • Release the volume button flex cable on the right.
    • Release the pop connector on the motherboard located to the left of the SIM card port.
    Спросите у FixBot
  8. Samsung Droid Charge SIM Card Port Replacement: шаг 8, изображение 1 из 2 Samsung Droid Charge SIM Card Port Replacement: шаг 8, изображение 2 из 2
    • Your SIM card port is now unattached.
    • Remove SIM card port from motherboard.
    Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
Lucas Carter
Участник с: 09/27/12
190 Репутация
1 руководство автора
Команда
Cal Poly, Team 15-44, Forte Fall 2012 Участник Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 48
За всё время: 2,839
