Samsung Droid Charge Screen Replacement
Выберете то, что вам нужно
    1. Samsung Droid Charge Screen Replacement, Rear Cover: шаг 1, изображение 1 из 1
      • Open up the back case on the phone from the groove in the bottom of the phone.
      • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
      Спросите у FixBot
      Добавить комментарий
    1. Samsung Droid Charge Screen Replacement, Battery: шаг 2, изображение 1 из 1
      • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
      • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
      Спросите у FixBot
    1. Samsung Droid Charge Screen Replacement, microSD: шаг 3, изображение 1 из 1
      • Push the SD card further into its metal slot until you hear a click.
      • Release the card, and it should automatically eject itself.
      • Remove the SD card.
      Спросите у FixBot
    1. Samsung Droid Charge Screen Replacement, SIM Card: шаг 4, изображение 1 из 1
      • Slide the SIM card out of its casing by pushing on it and sliding it upward.
      Спросите у FixBot
    1. Samsung Droid Charge Screen Replacement, Screen: шаг 5, изображение 1 из 1
      • Locate the 7 small black screws located around the edge of the phone under the battery cover.
      • With a small Philips head screwdriver, remove each of the screws and place them in a secure location.
      Спросите у FixBot
    2. Samsung Droid Charge Screen Replacement: шаг 6, изображение 1 из 1
      • Locate your pry tool.
      • Insert the pry tool into the plastic edge that runs along the sides of the phone. Doing so will allow you to remove part of the back casing.
      • Use a prying motion to lift the casing up.
      • Repeat this motion all around the screen edge until the casing pops off.
      Спросите у FixBot
    3. Samsung Droid Charge Screen Replacement: шаг 7, изображение 1 из 1
      • Release the one pop connector for the motherboard located on the right.
      • Release the volume button flex cable on the right.
      • Release the power button flex cable on the right.
      • Now the motherboard can be removed. Simply lift out the motherboard and set aside.
      Спросите у FixBot
    4. Samsung Droid Charge Screen Replacement: шаг 8, изображение 1 из 3 Samsung Droid Charge Screen Replacement: шаг 8, изображение 2 из 3 Samsung Droid Charge Screen Replacement: шаг 8, изображение 3 из 3
      • Using a hairdryer or heat gun, warm the phone. Doing so will warm the adhesive holding the screen in place, allowing us to continue disassembling the device.
      • Use the pry tool to pry the screen off the casing. You may need to use force to overcome the adhesive.
      • Work carefully to prevent damage to the phone.
      Спросите у FixBot
    5. Samsung Droid Charge Screen Replacement: шаг 9, изображение 1 из 1
      • You can now swap out the old screen for your new one.
      Спросите у FixBot
Финишная прямая
6 человек успешно провели ремонт по этому руководству.
Luke Gordon
Участник с: 09/26/12
199 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 15-44, Forte Fall 2012 Участник Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 членов
Автор 54 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 25
За всё время: 3,487
