Samsung Epic 4G Camera Lens Replacement
Выберете то, что вам нужно
    1. Samsung Epic 4G Camera Lens Replacement, Phone Case: шаг 1, изображение 1 из 1
      • Slide your fingernail along the edge of the device and pull at the plastic backing.
      • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
      Спросите у FixBot
      Добавить комментарий
    2. Samsung Epic 4G Camera Lens Replacement: шаг 2, изображение 1 из 1
      • Pull at the plastic backing gently to remove it after hearing the snap sound.
      Спросите у FixBot
    1. Samsung Epic 4G Camera Lens Replacement, Battery: шаг 3, изображение 1 из 1
      • Remove the battery from the device by pulling the battery edge upwards.
      Спросите у FixBot
    1. Samsung Epic 4G Camera Lens Replacement, Removing the Memory Card:: шаг 4, изображение 1 из 1
      • Locate the memory card on the upper right-hand corner of the device.
      • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
      Спросите у FixBot
    2. Samsung Epic 4G Camera Lens Replacement, Removing the Back Housing: шаг 5, изображение 1 из 2 Samsung Epic 4G Camera Lens Replacement, Removing the Back Housing: шаг 5, изображение 2 из 2
      • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
      • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
      • While separating the two components, most of the buttons (including the power button) will fall out.
      Спросите у FixBot
    3. Samsung Epic 4G Camera Lens Replacement, Removing the Power Button: шаг 6, изображение 1 из 2 Samsung Epic 4G Camera Lens Replacement, Removing the Power Button: шаг 6, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Remove the power button using tweezers if it did not fall out in the previous step.
      • At this point, you can replace the power button with a new one from a manufacturer.
      Спросите у FixBot
    1. Samsung Epic 4G Camera Lens Replacement, Micro USB Port: шаг 7, изображение 1 из 1
      • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
      • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
      • Do not rip the white cables out of the device.
      Спросите у FixBot
    2. Samsung Epic 4G Camera Lens Replacement, Removing the Antenna Assembly: шаг 8, изображение 1 из 2 Samsung Epic 4G Camera Lens Replacement, Removing the Antenna Assembly: шаг 8, изображение 2 из 2
      • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
      • Snap the antenna assembly out of the device gently using your fingers.
      Спросите у FixBot
    3. Samsung Epic 4G Camera Lens Replacement, Removing the Flex Cable: шаг 9, изображение 1 из 2 Samsung Epic 4G Camera Lens Replacement, Removing the Flex Cable: шаг 9, изображение 2 из 2
      • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
      • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
      Спросите у FixBot
    4. Samsung Epic 4G Camera Lens Replacement: шаг 10, изображение 1 из 1
      • Lift and remove the motherboard from the device.
      • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
      Спросите у FixBot
    1. Samsung Epic 4G Camera Lens Replacement, Camera Lens: шаг 11, изображение 1 из 1
      • Remove and replace the camera lens with a new one from a manufacturer.
      Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
Andrew Cunningham
Участник с: 10/03/12
273 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 24-25, Regan Fall 2012 Участник Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 членов
Автор 63 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 28
За всё время: 1,448
