Введение
Use this guide to replace a cracked Touch Screen / Digitizer or LCD.
Выберете то, что вам нужно
Insert plastic opening tool under back cover.
Apply pressure on tool while using a downward motion to pop off back cover.
Pry the top cover upward to remove it from the phone.
Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
Insert plastic opening tool under top cover.
Using hand slide top cover away from phone.
Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
Insert plastic opening tool between back assembly and phone.
Pry the back assembly away from phone.
Insert the pointed end of a spudger into the gap in the round housing frame.
Using spudger to remove vibrator remove from the adhesive.
Use the flat end of a spudger to disconnect the camera assembly cable.
Insert the spudger under each corner ribbon cable and lift them out of the way.
Insert a plastic pry tool into the gap between motherboard and base of phone
Tilt the motherboard up carefully.
Use a spudger to pry the connector from the socket on the motherboard.
Lift motherboard from frame.
Insert flat end of spudger between support panel and front assembly.
Using a spudger pry up to create opening to insert plastic opening tool.
Insert a plactic opening tool in opening.
Use plastic opening tool to pry around the edge of support panel to free it from front assembly.
Insert the pointed end of a spudger into gap.
Lift spudger away from support plate to remove headphone component.
Use the flat end of the spudger to remove headphone jack component from rectangular housing.
The the flat end of a spudger between componet and frame.
Use the the spudger to lift the componet from the frame.
Insert the spudger between blue flim and the back of the LCD.
Using the spudger lift blue film away from LCD.
Insert a plastic opening tool between LCD and Digitizer screen.
Use plastic opening tool to pry and lift the LCD from the glass screen.
3 человек успешно провели ремонт по этому руководству.
