Samsung Galaxy A70 Screen Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy A70 Screen  Replacement, Eject the SIM tray: шаг 1, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement, Eject the SIM tray: шаг 1, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement, Eject the SIM tray: шаг 1, изображение 3 из 3
    • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
    • Press firmly to eject the tray and remove it.
  2. Samsung Galaxy A70 Screen  Replacement, Soften the adhesive: шаг 2, изображение 1 из 1
    • Switch off your Galaxy A70.
    • Heat an iOpener and use it to soften the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  3. Samsung Galaxy A70 Screen  Replacement, Create a gap: шаг 3, изображение 1 из 2 Samsung Galaxy A70 Screen  Replacement, Create a gap: шаг 3, изображение 2 из 2
    • Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
    • Pull on the suction cup to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 4, изображение 3 из 3
    • Slide the opening pick along the edge to the bottom right corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
    • Once you have inserted an opening pick, feel free to remove the suction cup or continue to use it for a better grip during the removal procedure.
  5. Samsung Galaxy A70 Screen  Replacement: шаг 5, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement: шаг 5, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement: шаг 5, изображение 3 из 3
    • Insert a second opening pick underneath the bottom right corner of the back cover.
    • Slide the opening pick along the edge to the top right corner.
    • If you have trouble with cutting, you can use the iOpener again to soften the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  6. Samsung Galaxy A70 Screen  Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy A70 Screen  Replacement: шаг 6, изображение 2 из 2
    • Insert a third opening pick underneath the top right corner of the back cover.
    • Slide the tip of the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A70 Screen  Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement: шаг 7, изображение 3 из 3
    • Insert a fourth opening pick underneath the top left corner.
    • Slide the opening pick along the left edge of your phone to cut the adhesive.
  8. Samsung Galaxy A70 Screen  Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy A70 Screen  Replacement: шаг 8, изображение 2 из 2
    • Insert a fifth opening pick underneath the bottom left corner.
    • Slide it along the the bottom edge to cut the remaining adhesive.
  9. Samsung Galaxy A70 Screen  Replacement, Remove the back cover: шаг 9, изображение 1 из 1
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond — a stack of heavy books works well.
  10. Samsung Galaxy A70 Screen  Replacement, Unscrew the midframe: шаг 10, изображение 1 из 1
    • Use a Phillips screwdriver to remove the fourteen 4.0 mm-long screws that secure the midframe.
  11. Samsung Galaxy A70 Screen  Replacement, Insert an opening pick: шаг 11, изображение 1 из 2 Samsung Galaxy A70 Screen  Replacement, Insert an opening pick: шаг 11, изображение 2 из 2
    • The midframe is held in place by plastic clips.
    • Insert an opening pick between the midframe and front panel assembly on the right edge of the phone near the volume button.
  12. Samsung Galaxy A70 Screen  Replacement, Detach the plastic clips: шаг 12, изображение 1 из 2 Samsung Galaxy A70 Screen  Replacement, Detach the plastic clips: шаг 12, изображение 2 из 2
    • Slide the opening pick to the bottom right corner to detach the plastic clips.
  13. Samsung Galaxy A70 Screen  Replacement: шаг 13, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement: шаг 13, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement: шаг 13, изображение 3 из 3
    • Continue sliding the opening around the bottom right corner to the bottom left corner to detach the plastic clips.
  14. Samsung Galaxy A70 Screen  Replacement: шаг 14, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement: шаг 14, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement: шаг 14, изображение 3 из 3
    • Slide the opening pick along the left edge to detach the plastic clips.
  15. Samsung Galaxy A70 Screen  Replacement, Remove the midframe: шаг 15, изображение 1 из 1
    • Remove the midframe.
  16. Samsung Galaxy A70 Screen  Replacement, Disconnect the battery: шаг 16, изображение 1 из 2 Samsung Galaxy A70 Screen  Replacement, Disconnect the battery: шаг 16, изображение 2 из 2
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
  17. Samsung Galaxy A70 Screen  Replacement, Disconnect the display connector: шаг 17, изображение 1 из 2 Samsung Galaxy A70 Screen  Replacement, Disconnect the display connector: шаг 17, изображение 2 из 2
    • Use the flat edge of a spudger to pry up and disconnect the display connector from its daughterboard socket.
  18. Samsung Galaxy A70 Screen  Replacement, Apply a heated iOpener: шаг 18, изображение 1 из 1
    • Apply an heated iOpener to the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  19. Samsung Galaxy A70 Screen  Replacement, Create a gap: шаг 19, изображение 1 из 2 Samsung Galaxy A70 Screen  Replacement, Create a gap: шаг 19, изображение 2 из 2
    • Apply a suction cup to the right edge of the display.
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull up the suction cup with strong, steady force to create a gap.
    • Insert the tip of an opening pick into the gap.
  20. Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 20, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 20, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 20, изображение 3 из 3
    • Slide the opening pick to the bottom right corner to slice the adhesive.
  21. Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 21, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 21, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 21, изображение 3 из 3
    • Insert a second opening pick underneath the bottom right corner.
    • Slide the opening pick along the right edge of your phone. Leave the opening pick in the top right corner.
    • Leave both opening picks in their place to prevent the adhesive from resealing.
  22. Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 22, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 22, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 22, изображение 3 из 3
    • Insert a third opening pick underneath the top right corner.
    • Slide the opening pick along the top edge to slice the adhesive.
    • When you slice near the front facing camera, insert only the tip (3 mm) of the opening pick to avoid smearing or damaging the camera.
  23. Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 23, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 23, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement, Slice the adhesive: шаг 23, изображение 3 из 3
    • Slide the opening pick along the left edge to cut the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  24. Samsung Galaxy A70 Screen  Replacement, Slice the remaining adhesive: шаг 24, изображение 1 из 2 Samsung Galaxy A70 Screen  Replacement, Slice the remaining adhesive: шаг 24, изображение 2 из 2
    • Slide the opening pick along the bottom edge to cut the remaining adhesive.
  25. Samsung Galaxy A70 Screen  Replacement, Reapply a iOpener: шаг 25, изображение 1 из 2 Samsung Galaxy A70 Screen  Replacement, Reapply a iOpener: шаг 25, изображение 2 из 2
    • Reapply a heated iOpener to the screen to loosen the adhesive underneath.
    • The remaining adhesive holding the screen to the midframe is located in the center.
    • Do not use the plastic card underneath the bottom end of the screen in the following steps to avoid tearing the display flex cable.
  26. Samsung Galaxy A70 Screen  Replacement, Cut the adhesive: шаг 26, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement, Cut the adhesive: шаг 26, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement, Cut the adhesive: шаг 26, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    • Insert a plastic card on the left edge into the gap between display and the phone assembly.
    • Press the plastic card in and slide it back and forth until you cut through the entire adhesive.
    • Once you are sure you cut through the adhesive, remove the four opening picks from the corners.
    • Do not remove the screen completely yet. The display cable is still threaded through the midframe.
  27. Samsung Galaxy A70 Screen  Replacement: шаг 27, изображение 1 из 3 Samsung Galaxy A70 Screen  Replacement: шаг 27, изображение 2 из 3 Samsung Galaxy A70 Screen  Replacement: шаг 27, изображение 3 из 3
    • Carefully thread the display cable through the frame.
  28. Samsung Galaxy A70 Screen  Replacement, Remove the screen: шаг 28, изображение 1 из 1
    • Remove the screen.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
44 человек успешно провели ремонт по этому руководству.
Adriana Zwink
Участник с: 12/18/19
63 984 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Staff
124 членов
Автор 24 166 руководств
8 Комментарии к руководству
Guide is very useful and changed display is working. I think it will be good to order new display with the frame, I damaged one side of the displays frame. The display has strong adhesive or I had not enough patience :-). I thought that the display will meltdown - I have to warm it 4 times.
Andy B - Ответить Поделиться
Hello! Can I apply this procedure to my Samsung A21s too? The touchscreen of my Samsung A21s is unresponsive or responding incorrectly. I tried touching a certain part of the screen but ends up selecting something else instead.
Jaegger - Ответить Поделиться
Very useful 👌
henok kidane - Ответить Поделиться
Very useful and well explanatory
adeigbala - Ответить Поделиться
This devices could be easy to service, however it is not in intrerest of the manufacturer.... it should be more advantageous for the user to get a new product than to pay for service if he cannot replace it himself. I have an Volvo 850 year 1995. Complete guide from service manual for the engine head general overhaul and timing belt job is much shorter than this, and everything you need is T45, 10 and 13mm socket with wranch....
Sebastian Kirchhoff - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 15
За последние 7 дней: 70
За последние 30 дней: 480
За всё время: 47,523
