Samsung Galaxy Note 8.0 USB Port Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Note 8.0 USB Port Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
    Спросите у FixBot
    Добавить комментарий
  2. Samsung Galaxy Note 8.0 USB Port Replacement: шаг 2, изображение 1 из 1
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
    Спросите у FixBot
  3. Samsung Galaxy Note 8.0 USB Port Replacement: шаг 3, изображение 1 из 1
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
    Спросите у FixBot
  4. Samsung Galaxy Note 8.0 USB Port Replacement, Battery: шаг 4, изображение 1 из 2 Samsung Galaxy Note 8.0 USB Port Replacement, Battery: шаг 4, изображение 2 из 2
    • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
    Спросите у FixBot
  5. Samsung Galaxy Note 8.0 USB Port Replacement: шаг 5, изображение 1 из 1
    • Lift the top left corner of the battery up by the black tab.
    Спросите у FixBot
  6. Samsung Galaxy Note 8.0 USB Port Replacement: шаг 6, изображение 1 из 1
    • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
    Спросите у FixBot
  7. Samsung Galaxy Note 8.0 USB Port Replacement, Micro USB Port: шаг 7, изображение 1 из 1
    • Remove the two 4.5-mm Phillips head screws from the micro USB Port using a Phillips #00 screwdriver.
    • Remove the silver 3-mm Phillips head screw from the silver metal strip using a Phillips #00 screwdriver. This strip covers the connection to the mother board and will be removed in a later step.
    Спросите у FixBot
  8. Samsung Galaxy Note 8.0 USB Port Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy Note 8.0 USB Port Replacement: шаг 8, изображение 2 из 2
    • Gently lift up the gold connector on the left side of the board.
    Спросите у FixBot
  9. Samsung Galaxy Note 8.0 USB Port Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy Note 8.0 USB Port Replacement: шаг 9, изображение 2 из 2
    • Gently lift up the teal connector on the left side of the board.
    Спросите у FixBot
  10. Samsung Galaxy Note 8.0 USB Port Replacement: шаг 10, изображение 1 из 1
    • Gently pry off the silver plate.
    Спросите у FixBot
  11. Samsung Galaxy Note 8.0 USB Port Replacement: шаг 11, изображение 1 из 1
    • Gently lift up the large black connector on the right side of the component. This is the connector that was underneath the silver plate removed in the previous step.
    Спросите у FixBot
  12. Samsung Galaxy Note 8.0 USB Port Replacement: шаг 12, изображение 1 из 1
    • Remove micro USB Port from its housing.
    Спросите у FixBot
Заключение
55 человек успешно провели ремонт по этому руководству.
Joel
Участник с: 09/23/14
1 878 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 12-2, Blackwell Fall 2014 Участник USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 членов
Автор 16 руководств
13 Комментарии к руководству
Did it, in spite of unable to remove 2 batt screws due to stripping them. I wish there was a guide to prying open the case, it was very scary.
I see you have tools for removing striped 4.5 mm screws!
Jim Welch - Ответить Поделиться
I found this guide extremely useful, although i need a new port i didn't have the time to wait for delivery so i followed the guide hoping if i cleaned the part of any dust etc it might charge again temporarily and it did! It wasn't dusty but i did notice the flat plate inside the port wasn't straight so i wedged a flathead in to level it out. I think that was my problem.
Grateful i haven't had to spend unnecessary fees on repair.
Thank You!!!
Candice Aburrow - Ответить Поделиться
Thanks! The flat plate inside the connector was bent over to one side. I bent it back like you did and now it works fine. I was ready to trash it. Thank you, thank you.
ddolin1 - Ответить Поделиться
Hi! How do you guys know if it's the USB port that's broken, and not the battery? My Tab wont turn on... :(
rdablacksilhouette - Ответить Поделиться
the most difficult, is to open the plastic shell...
Cool tuto !
denisgaume - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 17
За последние 30 дней: 50
За всё время: 41,627
