Введение
If your device is unable to read your SD card, you may need to replace your port. This guide will show you how to safely replace your SD port.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
Pop open the orange wire tab connected to the SD port with the plastic opening tool.
Using the plastic end of the tweezers pop up the orange tab connecting the SD port to the device.
