Введение
Follow this guide to remove and replace the display assembly for your Samsung Galaxy Note5. The display assembly includes the front glass and the OLED panel.
This guide instructs you to replace only the display while leaving the original frame, logic board, and battery in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure—transplanting your phone's internals and installing a new battery. Make sure you have the correct part before starting this guide.
Note: If the frame is damaged or bent, it's important to replace it, or else the new screen may not mount correctly and can suffer damage from uneven pressure.
Warning: The process of separating the display from the frame usually destroys the display, so don't follow this guide unless you intend to replace the display.
Выберете то, что вам нужно
Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray at the top of the phone.
Press to eject the tray. This may require some force.
Remove the SIM card tray.
Using your fingernail, push the S-Pen button until it clicks and pops out of the phone.
Remove the S-Pen.
Apply a heated iOpener to the bottom of the phone for about two minutes.
Apply a suction cup as close as possible to the bottom edge of the phone.
Lift on the suction cup and insert an opening pick under the rear glass.
Slide the pick down the bottom edge of the phone.
Leave the pick in place to prevent the adhesive from resealing, and grab another pick as you proceed to the next step.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick in each edge of the phone as you continue to the next to prevent the adhesive from resealing.
Use an opening pick to cut any remaining adhesive around the edges of the glass.
Lift the glass and remove it from the phone.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99
Use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Hold the midframe by the edges and lift it upwards while pushing down against the battery with one finger.
Remove the midframe.
Using the flat end of a spudger, lift the battery connector straight up from its socket on the motherboard.
Using the flat end of a spudger, disconnect the earpiece connector.
Holding the motherboard by the top corners, hinge it upwards while clearing flex cables out of its path.
Using the flat end of a spudger, disconnect the daughterboard connector from the motherboard.
Remove the motherboard.
Prepare an iOpener and apply it to the left edge of the display for about two minutes.
Insert an opening pick between the plastic frame and the display assembly on the same edge you just heated.
Slide the opening pick down the battery-side of the phone, separating the adhesive.
Stop when you get to the bottom of the battery to avoid damaging delicate capacitive buttons at the bottom of the display.
Go slowly so that the tip doesn't slip out of the seam. If sliding becomes difficult, reheat and reapply the iOpener.
Leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
Heat an iOpener and apply it to the non-battery-edge of the phone.
Insert a pick no more than 0.25 inches (~6 mm) into the bottom edge of the phone.
Carefully slide the pick along the edge, starting at the headphone jack, until you reach just past the charging port.
Slide an opening pick from the battery edge battery edge of the phone along the edge of the phone to safely cut over the capacitive button.
Leave the pick in place as you proceed to the next button.
Insert an opening pick under the bottom edge of the display directly below the daughterboard ribbon cable to cut over the other capacitive button.
Leave the pick in place.
Slide an opening pick down the non-battery-edge of the phone, separating the adhesive.
The non-battery-edge contains a wider swath of adhesive than the other sides. Insert the opening pick as deep as you can to cut through all of it.
Cut along the top edge of the phone, making sure not to insert the pick more than 0.25 inches (~6 mm) to avoid damaging the front-facing sensors.
Use the opening picks to cut any remaining adhesive holding the display to the frame.
Swing the frame away from the display assembly, threading the touchscreen connector through the frame.
Lift the frame away from the display assembly, threading the display connector through the frame.
Remove the frame.
After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
To reassemble your device, follow the above steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
32 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Sorry to say this but this does not video had me cause a problem to the USB charging Board ribbon.
it mentioned starting removing the front panel from down, not mentioning that there is a fine ribbon that can be damaged!
you should start from Top.
apparently the Battery had previously been removed because I could not remove this easy.
I found another video on YouTube which helped me diagnose the error and was more informative.
