Samsung Galaxy S10+ Battery Replacement
Выберете то, что вам нужно
Видео обзор
  1. Samsung Galaxy S10+ Battery Replacement, Heat the back cover: шаг 1, изображение 1 из 3 Samsung Galaxy S10+ Battery Replacement, Heat the back cover: шаг 1, изображение 2 из 3 Samsung Galaxy S10+ Battery Replacement, Heat the back cover: шаг 1, изображение 3 из 3
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
  2. Samsung Galaxy S10+ Battery Replacement, Create an opening gap: шаг 2, изображение 1 из 3 Samsung Galaxy S10+ Battery Replacement, Create an opening gap: шаг 2, изображение 2 из 3 Samsung Galaxy S10+ Battery Replacement, Create an opening gap: шаг 2, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts.
    • If you are having trouble creating a gap, your best bet is to apply more heat to the edge and try the previous step again.
    • You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    • Do not apply excessive force with the pick, or you will risk cracking the back cover glass.
  3. Samsung Galaxy S10+ Battery Replacement: шаг 3, изображение 1 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 3, изображение 2 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 3, изображение 3 из 3
    • Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
    • Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
    • Press the edge of an opening tool into the seam between the back cover and the frame.
    • Slide the opening tool back and forth along the seam a few times.
  4. Samsung Galaxy S10+ Battery Replacement, Slice through the adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy S10+ Battery Replacement, Slice through the adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy S10+ Battery Replacement, Slice through the adhesive: шаг 4, изображение 3 из 3
    • Slide the opening pick along the edge of the phone, slicing through the adhesive.
    • Do not attempt to slice the adhesive holding the corners down before applying heat. If you do, you may crack the back cover.
    • Leave a pick in the seam to prevent the adhesive from re-sealing.
  5. Samsung Galaxy S10+ Battery Replacement: шаг 5, изображение 1 из 1
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
  6. Samsung Galaxy S10+ Battery Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy S10+ Battery Replacement: шаг 6, изображение 2 из 2
    • Insert an opening pick into the right edge near the bottom right corner.
    • Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
    • If the cutting feels difficult, re-apply heat to the edge before continuing.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  7. Samsung Galaxy S10+ Battery Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 7, изображение 3 из 3
    • Continue heating and slicing around the remaining edges of the phone.
    • When cutting around corners, be sure that the corner is thoroughly heated.
  8. Samsung Galaxy S10+ Battery Replacement: шаг 8, изображение 1 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 8, изображение 2 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 8, изображение 3 из 3
    • Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to reinstall the back cover, transfer and install the camera bezel, and replace the adhesive.
  9. Samsung Galaxy S10+ Battery Replacement, Remove the midframe: шаг 9, изображение 1 из 1
    • Remove the nine 4 mm Phillips screws securing the top midframe to the phone.
  10. Samsung Galaxy S10+ Battery Replacement: шаг 10, изображение 1 из 2 Samsung Galaxy S10+ Battery Replacement: шаг 10, изображение 2 из 2
    • The midframe is still held in place by a few plastic clips around the edge.
    • Insert the point of a spudger into the notch on the right edge of the midframe, near the Bixby button.
    • Pry up to loosen the midframe from the phone.
  11. Samsung Galaxy S10+ Battery Replacement: шаг 11, изображение 1 из 2 Samsung Galaxy S10+ Battery Replacement: шаг 11, изображение 2 из 2
    • Insert the point of a spudger into the notch on the left edge of the phone, located near the power button.
  12. Samsung Galaxy S10+ Battery Replacement: шаг 12, изображение 1 из 1
  13. Samsung Galaxy S10+ Battery Replacement, Disconnect the battery: шаг 13, изображение 1 из 3 Samsung Galaxy S10+ Battery Replacement, Disconnect the battery: шаг 13, изображение 2 из 3 Samsung Galaxy S10+ Battery Replacement, Disconnect the battery: шаг 13, изображение 3 из 3
    • Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
    • Pry upwards to disconnect the connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
  14. Samsung Galaxy S10+ Battery Replacement, Battery: шаг 14, изображение 1 из 2 Samsung Galaxy S10+ Battery Replacement, Battery: шаг 14, изображение 2 из 2
    • The battery is heavily glued in place. Note the marked areas under the battery:
    • The frame, where the battery is held by strong adhesive
    • A cutout in the frame, exposing the fragile display assembly underneath. Be careful when prying in this area, or you may damage the display.
  15. Samsung Galaxy S10+ Battery Replacement: шаг 15, изображение 1 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 15, изображение 2 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 15, изображение 3 из 3
    • Applying high concentration (over 90%) isopropyl alcohol to the battery will make the battery removal significantly easier.
    • Lift the bottom edge of the phone up and hold the phone in a tilted position.
    • Apply drops of isopropyl alcohol into the crevice between the battery and the phone's bottom midframe.
    • Hold the phone in a tilted position for a minute to allow the isopropyl alcohol to soak into the adhesive.
    • Alternatively, heat an iOpener and apply it to the right side of the front of the phone for two minutes.
  16. Samsung Galaxy S10+ Battery Replacement: шаг 16, изображение 1 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 16, изображение 2 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 16, изображение 3 из 3
    • Insert the corner of an opening card into the crevice between the battery and the bottom midframe.
    • Pry the battery out of its recess.
    • If the battery does not budge, the adhesive is not sufficiently weakened.
    • Use an opening pick, an opening tool, or a spudger to pry the battery out. Do not use metal tools.
    • Repeat the isopropyl alcohol application step and try again.
    • Try applying more heat with an iOpener.
  17. Samsung Galaxy S10+ Battery Replacement: шаг 17, изображение 1 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 17, изображение 2 из 3 Samsung Galaxy S10+ Battery Replacement: шаг 17, изображение 3 из 3
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Follow this guide to replace the battery adhesive.
    • Temporarily re-connect the battery to the motherboard before sticking the battery in place. This ensures proper battery alignment.
    • Apply pre-cut adhesive, or double-sided tape to the frame first before pressing the battery into the recess.
    • Do not apply adhesive on the exposed display back.
Заключение
For optimal performance, calibrate your newly installed battery after completing this guide.
44 участников успешно повторили данное руководство.
Arthur Shi
Участник с: 01/03/18
252 818 Репутация
Автор 526 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
13 Комментариев
The hardest part was actually getting rid of all the adhesive residue everywhere. That step took the longest. The battery removal went very quickly, surprisingly so.
isely - Ответить
Worked great to replace my swollen battery, and thanks to it being swollen I could actually skip the steps to pry open the back cover. Anyway, from my experience everything is correct, the only downside is that I used a little more than a few drops to loosen the battery and after the whole annoyance of removing the glue and placing the new battery I turned on the phone to check everything was working and my back cameras were blurry.... yeah, too much alcohol, had to clean them up very well.... but the sad part is that some of the alcohol made it's way to the front cameras... now they are both blurry.
Brian - Ответить
لم استطيع أشحن البطارية خارج أمريكا اذاً ما الفائدة ؟
Omar Al - Ответить
I agree with isely - the toughest part was removing all the left over adhesive. Removing the battery was a bit of a pain as well, even with isopropyl alcohol. I recommend using heat to remove the battery.
To get rid of the excess adhesive, I recommend using a heat gun and peeling it up with your thumb. As long as it's malleable, you can slowly peel it up to create a ball of adhesive and hopefully get most of it off at once. I was trying Q-Tips with isopropyl alcohol and that mostly just spread around the adhesive and got fluff from the Q-Tip over the phone.
Finally, I recommend buying a precut adhesive card to glue it back in place. It took me quite a while to cut a bunch of strips with my 2mm double sided tape.
Geoff Johnston - Ответить
And my phone is ruined because, presumably, the alcohol leaked somehow and destroyed the lens. Gonna have to get a new phone now anyway. Please add proper precautions to the instructions to avoid wrecking the lens. I didn't make any careless splashes or drips.
Alan Miller - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 51
За последние 7 дней: 384
За последние 30 дней: 1,793
За всё время: 111,143
