How to Apply Custom-cut Battery Adhesive
Выберете то, что вам нужно
    1. How to Apply Custom-cut Battery Adhesive, How to Apply Custom-cut Battery Adhesive: шаг 1, изображение 1 из 1
      • Remove any remaining adhesive from the phone frame, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      Спросите у FixBot
      Добавить комментарий
    2. How to Apply Custom-cut Battery Adhesive: шаг 2, изображение 1 из 3 How to Apply Custom-cut Battery Adhesive: шаг 2, изображение 2 из 3 How to Apply Custom-cut Battery Adhesive: шаг 2, изображение 3 из 3
      • Before you begin, figure out how the pre-cut adhesive strip should be oriented and which surface to attach it to.
      • If your pre-cut adhesive has pull tabs facing the center hole, the adhesive will attach to the phone's battery well first.
      • If your pre-cut adhesive strip has pull tabs on the outer perimeter, the adhesive will attach to the battery first.
      • Peel the clear plastic liner off of the pre-cut adhesive strip, exposing the adhesive.
      • Line up a long edge of the adhesive with the proper surface, as determined above.
      • Carefully set the adhesive down on the surface.
      • The adhesive is very sticky, so you have only one chance to align it.
      Спросите у FixBot
    3. How to Apply Custom-cut Battery Adhesive: шаг 3, изображение 1 из 2 How to Apply Custom-cut Battery Adhesive: шаг 3, изображение 2 из 2
      • Once the adhesive is aligned, use your fingers to press the adhesive into place.
      • When you are ready to stick the battery onto the frame, carefully peel away the blue plastic liner to expose the adhesive.
      • Set the battery lightly in place.
      • Plug in the battery connector temporarily to ensure that the cable reaches the socket.
      • Press the battery perimeter firmly with your fingers to help the adhesive bond.
      • Disconnect the battery before resuming re-assembly.
      Спросите у FixBot
Заключение
For optimal performance, after completing this guide, calibrate your newly installed battery.
172 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
344 877 Репутация
Автор 915 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 47 184 руководств
25 Комментарии к руководству
Fantastic job on the instructions ! I only wish I was able to find a solution, for removing the original glue from the back cover.
That is all I have left to do, and I have been unsuccessful for 6 to 8 hours of trying to find a way to get it off.
Lee Jones - Ответить Поделиться
Hey Lee,
Your best chance is using high concentration (over 90%) isopropyl alcohol . If you can’t get the surface completely clean, that’s alright. Just try to get all large adhesive residue off, so that the battery and new adhesive will lie flat in the battery well.
Arthur Shi - Ответить Поделиться
I accidentally rubbed off some of the black paste thing under the battery when cleaning it for the new battery adhesive strip. Should I be worried??
Henry Dang - Ответить Поделиться
Hi Henry,
The black paste is possibly the graphite pad stuck onto the back of the display, which channels heat from the phone to dissipate through the display. There shouldn’t be any damage to your phone!
Hi Arthur,
A big respect & thank you for the instruction to replace the battery. I couldn't be more happier because I did it myself thanks to you & ifixit team. It only took 30 minutes from start to finish. Just waiting on the back glass to arrive other wise excellent job on your side and awesome job to ifixit. I will have to buy higher concentration of isopropyl to wipe those big adhesive before I put the glass.
kar.kunal - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 37
За последние 7 дней: 253
За последние 30 дней: 1,106
За всё время: 123,724
