Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Heat the bottom edge: шаг 1, изображение 1 из 1
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the bottom edge adhesive: шаг 2, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the bottom edge adhesive: шаг 2, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the bottom edge adhesive: шаг 2, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken glass.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
  3. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 3, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 3, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 3, изображение 3 из 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
  4. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Heat the left edge: шаг 4, изображение 1 из 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  5. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the left edge adhesive: шаг 5, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the left edge adhesive: шаг 5, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the left edge adhesive: шаг 5, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
  6. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 6, изображение 2 из 2
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
  7. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 7, изображение 3 из 3
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass to prevent the adhesive from resealing.
  8. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Heat the right edge: шаг 8, изображение 1 из 1
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  9. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the right edge adhesive: шаг 9, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the right edge adhesive: шаг 9, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the right edge adhesive: шаг 9, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
  10. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 10, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 10, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 10, изображение 3 из 3
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
  11. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Heat the top edge: шаг 11, изображение 1 из 1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the top edge adhesive: шаг 12, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the top edge adhesive: шаг 12, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Separate the top edge adhesive: шаг 12, изображение 3 из 3
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
  13. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the back cover: шаг 13, изображение 1 из 2 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the back cover: шаг 13, изображение 2 из 2
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  14. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Unfasten the motherboard bracket: шаг 14, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Use a Phillips #00 screwdriver to remove the six 4 mm-long screws securing the motherboard bracket.
  15. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Unclip the motherboard bracket: шаг 15, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Unclip the motherboard bracket: шаг 15, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Unclip the motherboard bracket: шаг 15, изображение 3 из 3
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
    • Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
  16. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 16, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 16, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement: шаг 16, изображение 3 из 3
    • Gently tilt up the motherboard bracket so the orange battery connector is accessible.
  17. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Disconnect the battery: шаг 17, изображение 1 из 2 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Disconnect the battery: шаг 17, изображение 2 из 2
    • Use a spudger to pry up and disconnect the battery connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  18. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Disconnect the wireless charging coil: шаг 18, изображение 1 из 2 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Disconnect the wireless charging coil: шаг 18, изображение 2 из 2
    • Use a spudger to pry up and disconnect the wireless charging coil connector.
  19. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the wireless charging coil: шаг 19, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the wireless charging coil: шаг 19, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the wireless charging coil: шаг 19, изображение 3 из 3
    • Use a pair of tweezers to gently peel the wireless charging coil away from the device.
    • Remove the wireless charging coil.
    • During reassembly, first reconnect the charging coil and battery connectors and refasten the motherboard bracket screws to properly align everything into place, then firmly press the coil pad down to adhere it.
  20. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Unfasten the upper midframe: шаг 20, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the three 4 mm-long screws securing the upper midframe.
  21. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the upper midframe: шаг 21, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the upper midframe: шаг 21, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the upper midframe: шаг 21, изображение 3 из 3
    • Insert the pointed end of a spudger into the notch on the right side of the upper midframe and pry up to release the clips holding it in place.
    • Remove the upper midframe.
  22. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Disconnect the front-facing camera: шаг 22, изображение 1 из 2 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Disconnect the front-facing camera: шаг 22, изображение 2 из 2
    • Use a spudger to pry up and disconnect the front-facing camera flex cable from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  23. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Soften the camera module adhesive: шаг 23, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Soften the camera module adhesive: шаг 23, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Soften the camera module adhesive: шаг 23, изображение 3 из 3
    • Apply high concentration (over 90%) isopropyl alcohol to the gaps around the front-facing camera module to help soften the adhesive securing it into place.
    • Allow the alcohol 1-2 minutes to penetrate the adhesive.
  24. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the front-facing camera module: шаг 24, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the front-facing camera module: шаг 24, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the front-facing camera module: шаг 24, изображение 3 из 3
    • Use the flat end of a spudger to pry up bottom edge of the front-facing camera module.
    • The camera module is heavily cemented in place with a rubbery adhesive. If it doesn't budge even after using alcohol, you may need to cut the adhesive with a craft or utility knife to help release the module, or you risk damaging it during removal.
    • It is possible to pry up only the internal sensor and hardware components of the module without its plastic casing, which may damage the module. If you are replacing the module, this isn't an issue, and the following steps will describe how to remove the plastic casing separately.
    • If you must retain the camera module's functionality, you can try to reseat the sensor hardware back into its plastic casing before cutting and prying again, or proceed to the next step and reseat the sensor after removing the casing by itself.
    • Remove the front-facing camera module.
    • It is possible to reuse the existing camera module adhesive during reassembly, but if you need to replace it, you can do so with a pre-cut adhesive sheet.
  25. Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the camera module casing: шаг 25, изображение 1 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the camera module casing: шаг 25, изображение 2 из 3 Samsung Galaxy S20 Plus Front-Facing Camera Module Replacement, Remove the camera module casing: шаг 25, изображение 3 из 3
    • If you removed the camera module's internal components without its plastic casing, apply a few drops of high concentration (over 90%) isopropyl alcohol around the edges of the casing to soften the adhesive securing it into place.
    • Use a pair of tweezers to remove the plastic camera casing.
Заключение
After you've completed the repair, follow this guide to test your repair.
Еще один человек закончил это руководство.
Tarun Thiruma
Участник с: 11/20/19
35 391 Репутация
Автор 134 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 29
За последние 30 дней: 82
За всё время: 3,578
