Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Heat the bottom edge: шаг 1, изображение 1 из 1
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the bottom edge adhesive: шаг 2, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the bottom edge adhesive: шаг 2, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the bottom edge adhesive: шаг 2, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If the back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
  3. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Slice the adhesive: шаг 3, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Slice the adhesive: шаг 3, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Slice the adhesive: шаг 3, изображение 3 из 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
  4. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Heat the left edge: шаг 4, изображение 1 из 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  5. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the left edge adhesive: шаг 5, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the left edge adhesive: шаг 5, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the left edge adhesive: шаг 5, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
  6. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement: шаг 6, изображение 2 из 2
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
  7. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement: шаг 7, изображение 1 из 2 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement: шаг 7, изображение 2 из 2
    • Slide the pick towards the bottom edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the left edge of the glass near the bottom of the device to prevent the adhesive from resealing.
  8. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement: шаг 8, изображение 2 из 2
    • Insert another pick under the center of the left edge of the back cover.
    • Gradually slide the pick towards the top of the device to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass near the top of the device to prevent the adhesive from resealing.
  9. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Heat the right edge: шаг 9, изображение 1 из 1
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  10. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the right edge adhesive: шаг 10, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the right edge adhesive: шаг 10, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the right edge adhesive: шаг 10, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
  11. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement: шаг 11, изображение 1 из 2 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement: шаг 11, изображение 2 из 2
    • Leave your pick under the right edge of the glass near the bottom of the device to prevent the adhesive from resealing.
  12. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement: шаг 12, изображение 1 из 2 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement: шаг 12, изображение 2 из 2
    • Insert another pick underneath the center of the right edge of the back cover.
    • As you do this, the bottom edge of the back cover may release the three picks located there. If this occurs, set these picks aside as the bottom edge shouldn't reseal from this point onward.
  13. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Heat the top edge: шаг 13, изображение 1 из 1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  14. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the top edge adhesive: шаг 14, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the top edge adhesive: шаг 14, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Separate the top edge adhesive: шаг 14, изображение 3 из 3
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
  15. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the back cover: шаг 15, изображение 1 из 2 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the back cover: шаг 15, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Купить
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Disconnect the wireless charging coil: шаг 16, изображение 1 из 2 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Disconnect the wireless charging coil: шаг 16, изображение 2 из 2
    • Use a spudger to pry up and disconnect the wireless charging coil connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  17. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil: шаг 17, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil: шаг 17, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the wireless charging coil: шаг 17, изображение 3 из 3
    Купить
    • Use a pair of tweezers to gently peel the wireless charging coil away from the device.
    • Remove the wireless charging coil.
    • During reassembly, reconnect the wireless charging coil connector first to properly align it into place, then firmly press the rest of the coil down to adhere it.
  18. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Unfasten the motherboard bracket: шаг 18, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    Купить
    • Use a Phillips #00 screwdriver to remove the five 3.9 mm-long screws securing the motherboard bracket.
  19. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the motherboard bracket: шаг 19, изображение 1 из 1
    Купить
    • Use a pair of tweezers to unclip and remove the motherboard bracket.
  20. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Disconnect the battery: шаг 20, изображение 1 из 2 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Disconnect the battery: шаг 20, изображение 2 из 2
    • Use a spudger to pry up and disconnect the battery connector.
  21. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Unfasten the lower midframe: шаг 21, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the five 3.9 mm-long screws securing the loudspeaker and lower midframe.
  22. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the loudspeaker: шаг 22, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the loudspeaker: шаг 22, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the loudspeaker: шаг 22, изображение 3 из 3
    Купить
    • Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
    • Remove the loudspeaker and lower midframe.
  23. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Disconnect the daughterboard: шаг 23, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Disconnect the daughterboard: шаг 23, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Disconnect the daughterboard: шаг 23, изображение 3 из 3
    • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  24. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Disconnect the main flex cables: шаг 24, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Disconnect the main flex cables: шаг 24, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Disconnect the main flex cables: шаг 24, изображение 3 из 3
    • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
  25. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the main flex cables: шаг 25, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the main flex cables: шаг 25, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the main flex cables: шаг 25, изображение 3 из 3
    • Gently peel up and remove the main and auxiliary flex cables.
  26. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Unfasten the daughterboard: шаг 26, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the three 3.7 mm-long screws securing the USB-C port and daughterboard.
  27. Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard: шаг 27, изображение 1 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard: шаг 27, изображение 2 из 3 Samsung Galaxy S20 Ultra USB-C Port and Daughterboard Replacement, Remove the daughterboard: шаг 27, изображение 3 из 3
    Купить
    • Insert the pointed end of a spudger under the left edge of the daughterboard and pry up to release it from its recess.
    • Use a pair of tweezers to pull the daughterboard up and away from the bottom of the device and remove it.
Заключение
After you've completed the repair, follow this guide to test your repair.
2 участников успешно повторили данное руководство.
Tarun Thiruma
Участник с: 11/20/19
35 586 Репутация
Автор 134 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 34
За последние 30 дней: 139
За всё время: 13,575
