Samsung Galaxy S22 Ultra Battery Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S22 Ultra Battery Replacement, Heat the right edge: шаг 1, изображение 1 из 1
    • Let your phone's battery drain to below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  2. Samsung Galaxy S22 Ultra Battery Replacement, Adhesive information: шаг 2, изображение 1 из 2 Samsung Galaxy S22 Ultra Battery Replacement, Adhesive information: шаг 2, изображение 2 из 2
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  3. Samsung Galaxy S22 Ultra Battery Replacement, Insert an opening pick: шаг 3, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Insert an opening pick: шаг 3, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Insert an opening pick: шаг 3, изображение 3 из 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S22 Ultra Battery Replacement, Slice the right adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Slice the right adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Slice the right adhesive: шаг 4, изображение 3 из 3
    • Slide the pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick inserted near the bottom of the right edge to prevent the adhesive from resealing.
  5. Samsung Galaxy S22 Ultra Battery Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 6, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 6, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 6, изображение 3 из 3
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while slicing around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  7. Samsung Galaxy S22 Ultra Battery Replacement, Slice the bottom adhesive: шаг 7, изображение 1 из 2 Samsung Galaxy S22 Ultra Battery Replacement, Slice the bottom adhesive: шаг 7, изображение 2 из 2
    • Slide your opening pick to the bottom left corner to slice the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S22 Ultra Battery Replacement, Heat the left edge: шаг 8, изображение 1 из 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 9, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 9, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 9, изображение 3 из 3
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  10. Samsung Galaxy S22 Ultra Battery Replacement, Slice the left adhesive: шаг 10, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Slice the left adhesive: шаг 10, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Slice the left adhesive: шаг 10, изображение 3 из 3
    • Slide your opening pick along the left edge to slice the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  11. Samsung Galaxy S22 Ultra Battery Replacement, Heat the top edge: шаг 11, изображение 1 из 1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 12, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 12, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 12, изображение 3 из 3
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  13. Samsung Galaxy S22 Ultra Battery Replacement, Slice the top adhesive: шаг 13, изображение 1 из 2 Samsung Galaxy S22 Ultra Battery Replacement, Slice the top adhesive: шаг 13, изображение 2 из 2
    • Slide the pick to the top left corner to slice the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  14. Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 14, изображение 1 из 2 Samsung Galaxy S22 Ultra Battery Replacement, Separate the corner adhesive: шаг 14, изображение 2 из 2
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Insert an opening pick in the gap at the top left edge.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  15. Samsung Galaxy S22 Ultra Battery Replacement, Slice the remaining adhesive: шаг 15, изображение 1 из 2 Samsung Galaxy S22 Ultra Battery Replacement, Slice the remaining adhesive: шаг 15, изображение 2 из 2
    • Slide the pick toward the bottom camera to slice through the remaining adhesive, stopping before you reach the power button.
  16. Samsung Galaxy S22 Ultra Battery Replacement, Remove the back cover: шаг 16, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Remove the back cover: шаг 16, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Remove the back cover: шаг 16, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  17. Samsung Galaxy S22 Ultra Battery Replacement, Slice the adhesive: шаг 17, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Slice the adhesive: шаг 17, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Slice the adhesive: шаг 17, изображение 3 из 3
    • The wireless charging coil is lightly adhered to the battery.
    • Be careful not to strain or tear the display interconnect cable under the right side of the charging coil.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
  18. Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the NFC antenna and charging coil: шаг 18, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the NFC antenna and charging coil: шаг 18, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the NFC antenna and charging coil: шаг 18, изображение 3 из 3
    • Use the pointed end of a spudger to pry and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  19. Samsung Galaxy S22 Ultra Battery Replacement, Unfasten the NFC antenna and charging coil: шаг 19, изображение 1 из 1
    • Use your Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
  20. Samsung Galaxy S22 Ultra Battery Replacement, Unfasten the loudspeaker: шаг 20, изображение 1 из 1
    • Use your Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  21. Samsung Galaxy S22 Ultra Battery Replacement, Unclip the loudspeaker: шаг 21, изображение 1 из 2 Samsung Galaxy S22 Ultra Battery Replacement, Unclip the loudspeaker: шаг 21, изображение 2 из 2
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  22. Samsung Galaxy S22 Ultra Battery Replacement, Remove the charging coil and loudspeaker assembly: шаг 22, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Remove the charging coil and loudspeaker assembly: шаг 22, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Remove the charging coil and loudspeaker assembly: шаг 22, изображение 3 из 3
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
    • The wireless charging coil holds these parts together.
  23. Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the battery: шаг 23, изображение 1 из 2 Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the battery: шаг 23, изображение 2 из 2
    • Use the pointed end of your spudger to pry up and disconnect the battery press connector.
  24. Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the lower 5G mmWave antenna: шаг 24, изображение 1 из 2 Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the lower 5G mmWave antenna: шаг 24, изображение 2 из 2
    • Use the pointed end of your spudger to pry up and disconnect the lower 5G mmWave antenna press connector.
  25. Samsung Galaxy S22 Ultra Battery Replacement, Unfasten the lower 5G mmWave antenna: шаг 25, изображение 1 из 1
    • Use your Phillips screwdriver to remove the two 3.5 mm-long screws securing the antenna bracket.
  26. Samsung Galaxy S22 Ultra Battery Replacement, Remove the lower 5G mmWave antenna: шаг 26, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Remove the lower 5G mmWave antenna: шаг 26, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Remove the lower 5G mmWave antenna: шаг 26, изображение 3 из 3
    • Insert the pointed end of your spudger between the lower screw mount of the antenna bracket and the frame.
    • Pry up on the bracket until you can grab it with blunt nose tweezers or your fingers.
    • Remove the lower 5G mmWave antenna.
  27. Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the interconnect cables: шаг 27, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the interconnect cables: шаг 27, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the interconnect cables: шаг 27, изображение 3 из 3
    • Use the pointed end of your spudger to pry up and disconnect the primary interconnect cable from the motherboard.
    • Repeat for the secondary interconnect located to the left of the primary cable.
  28. Samsung Galaxy S22 Ultra Battery Replacement: шаг 28, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement: шаг 28, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement: шаг 28, изображение 3 из 3
    • Use the pointed end of your spudger to pry up and disconnect the primary interconnect cable from the charging board.
    • Repeat for the secondary interconnect cable.
  29. Samsung Galaxy S22 Ultra Battery Replacement, Remove the interconnect cables: шаг 29, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Remove the interconnect cables: шаг 29, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Remove the interconnect cables: шаг 29, изображение 3 из 3
    • Grab and remove the interconnect cables from the frame.
  30. Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the screen cable: шаг 30, изображение 1 из 2 Samsung Galaxy S22 Ultra Battery Replacement, Disconnect the screen cable: шаг 30, изображение 2 из 2
    • Use the pointed end of your spudger to pry up and disconnect the screen press connector from the motherboard.
  31. Samsung Galaxy S22 Ultra Battery Replacement: шаг 31, изображение 1 из 2 Samsung Galaxy S22 Ultra Battery Replacement: шаг 31, изображение 2 из 2
    • Use the pointed end of your spudger to pry up and disconnect the screen press connector from the bottom right corner of the phone.
  32. Samsung Galaxy S22 Ultra Battery Replacement, Remove the screen cable: шаг 32, изображение 1 из 1
    • Remove the screen cable.
  33. Samsung Galaxy S22 Ultra Battery Replacement, Apply isopropyl alcohol: шаг 33, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Apply isopropyl alcohol: шаг 33, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Apply isopropyl alcohol: шаг 33, изображение 3 из 3
    • Strong adhesive secures the battery to the frame.
    • Use a pipette or syringe to apply 1-2 drops of high-concentration isopropyl alcohol (greater than 90%) between the left edge of the battery and frame.
    • Using too much alcohol can damage the display.
    • Elevate the left edge of the phone for one minute to allow the isopropyl alcohol to flow under the battery and soften the adhesive.
  34. Samsung Galaxy S22 Ultra Battery Replacement, Separate the battery adhesive: шаг 34, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Separate the battery adhesive: шаг 34, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Separate the battery adhesive: шаг 34, изображение 3 из 3
    • Take care not to puncture the battery—it can leak dangerous chemicals and/or catch fire.
    • Apply a suction cup to the battery, as close to the center of the left edge as possible.
    • Insert the tip of an opening pick between the left edge of the battery and frame.
    • Push the opening pick down and rotate it so the long end is between the battery and frame.
  35. Samsung Galaxy S22 Ultra Battery Replacement: шаг 35, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement: шаг 35, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement: шаг 35, изображение 3 из 3
    • Take care not to crease or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Pull up on the suction cup with strong, steady force while prying the battery up with the opening pick.
    • Maintain constant pressure on the pick and suction cup until the battery separates from the frame.
    • Be patient and allow time for the adhesive to separate. If the battery doesn't budge, apply a few more drops of isopropyl alcohol and try again.
  36. Samsung Galaxy S22 Ultra Battery Replacement, Remove the battery: шаг 36, изображение 1 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Remove the battery: шаг 36, изображение 2 из 3 Samsung Galaxy S22 Ultra Battery Replacement, Remove the battery: шаг 36, изображение 3 из 3
    • Remove the battery.
    • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
    • Follow this guide to install your new battery.
Заключение
For optimal performance, calibrate your newly installed battery after completing this guide.
12 человек успешно провели ремонт по этому руководству.
Spencer Day
Участник с: 09/14/22
94 949 Репутация
Автор 662 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 453 руководств
Один комментарий
In order not to strip the Phillips head screws in steps 19-25 you should use a J0 Philips bit to fit properly and have the least chance to strip the head.
Josh Michaud - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 76
За последние 7 дней: 477
За последние 30 дней: 1,516
За всё время: 29,219
